I am trying to start an event after pressing and holding the FLASH built-in Nodemcu button for a specific time, I wrote two functions, one for debouncing and detecting the state, the other is to detect the pressing time, I'm not getting any result unless I decrease the input pressing time to less than 1s, which makes the button works as a single-push button, I think i have a problem with debouncing the button, I can't figure out where it is?
* @brief debounces the button and returns the current level high or low
* @return int the button state 0: low, 1: high, -1 indetermined
int button_state(int btn)
    int const DEBOUNCE = 200;
    static int hi = DEBOUNCE;
    static int lo = 0;
    if (digitalRead(buttonPin[btn]))
        if (hi < DEBOUNCE)
            hi++;
        if (lo > 0)
            lo--;
    else
        if (lo < DEBOUNCE)
            lo++;
        if (hi > 0)
            hi--;
if (hi == DEBOUNCE)
    return 1;
else if (lo == DEBOUNCE)
    return 0;
else
    return -1;
  • @brief Detects the button state and starts a time to calculate pressing duration
  • @param btn input button pin
  • @param PressTime Desired pressing duration to compare to
  • @return int returns 1 when PressTime is reached
*/ int PressNHold(int btn, int PressTime) { int lastButtonState = 0, Startpressed = 0, endPressed = 0, holdTime = 0, buttonState = button_state(btn); if(buttonState != -1) { if (buttonState != lastButtonState) { if (buttonState == 1) { Startpressed = millis(); } else { endPressed = millis(); holdTime = endPressed - Startpressed; if (holdTime >= PressTime) { Serial.printf("Button %d pressed for %ds or more\n", btn, holdTime); holdTime = 0; return 1; } } } } lastButtonState = buttonState; } .....
void loop {
if (PressNHold(buttonPin[1], 5 * 1000) == 1) { //launch your event }
alasa995
  • 33
turns out that it is very simple, I shouldn't put buttonPin[1] a variable for PressNHold, I had to put just1, buttonPin was used already in button_state, also, PressnHold local variables should be declared static to not get a reset after function execution.
alasa995
  • 33
