I bought a Sparkfun USB host shield a while ago and have been using it using my Logitech Extreme 3D Pro Joystick. There is some example code for that one which makes it nice and easy to work with. There is also some example code for a generic USB HID Joystick.
My goal is to be able to use any joystick I want with the shield. All the channels on each of my flight sticks are being detected but they all have issues like they are mapped wrongly and don't have a full range of motion.
I understand I need to use USBHID_desc to get the USB HID Descriptor (unique for each joystick right?) and plug those numbers somewhere into the USBHIDJoystick code, but I don't know where to put this information.
My problem boils down to how should I use the data recovered from the USBHID_desc program.
Any help would be appreciated as I'm at a bit of a loss
Thanks
Report Descriptor for Random Flight Stick
Start
0000: 05 01 09 04 A1 01 09 01 A1 00 05 01 09 30 09 31
0010: 15 00 26 FF 03 35 00 46 FF 03 65 00 75 0A 95 02
0020: 81 02 09 35 09 32 15 00 26 FF 01 35 00 46 FF 01
0030: 65 00 75 09 95 02 81 02 75 01 95 02 81 01 09 39
0040: 15 01 25 08 35 00 46 3B 01 65 14 75 08 95 01 81
0050: 02 05 09 19 01 29 06 15 00 25 01 35 00 45 01 75
0060: 01 95 06 81 02 75 01 95 0A 81 01 C0 C0
Usage Page Gen Desktop Ctrls(01)
Usage Game Pad
Collection Application
Usage Pointer
Collection Physical
Usage X
Usage Y
Logical Min(00)
Logical Max(FF03)
Physical Min(00)
Physical Max(FF03)
Unit(00)
Report Size(0A)
Report Count(02)
Input(00000010)
Usage Rz
Usage Z
Logical Min(00)
Logical Max(FF01)
Physical Min(00)
Physical Max(FF01)
Unit(00)
Report Size(09)
Report Count(02)
Input(00000010)
Report Size(01)
Report Count(02)
Input(00000001)
Usage Hat Switch
Logical Min(01)
Logical Max(08)
Physical Min(00)
Physical Max(3B01)
Unit(14)
Report Size(08)
Report Count(01)
Input(00000010)
Usage Page Button(09)
Usage Min(01)
Usage Max(06)
Logical Min(00)
Logical Max(01)
Physical Min(00)
Physical Max(01)
Report Size(01)
Report Count(06)
Input(00000010)
Report Size(01)
Report Count(0A)
Input(00000001)
End Collection
End Collection Game Pad Pointer X Y(02)(08)
Rz Z(00)(E3)
(00)(00)
Hat Switch(00)
Btn0001
(00) Btn0002
(01) Btn0003
(00) Btn0004
(00) Btn0005
(00) Btn0006
(00)
(00)(00)(00)(00)(00)(00)(00)(00)(00)(00)
USB HID Joystick .INO
#include <usbhid.h>
#include <hiduniversal.h>
#include <usbhub.h>
// Satisfy IDE, which only needs to see the include statment in the ino.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
#include <SPI.h>
#include "hidjoystickrptparser.h"
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
JoystickEvents JoyEvents;
JoystickReportParser Joy(&JoyEvents);
Serial.begin(115200);
#if !defined(MIPSEL)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
Serial.println("Start");
if (Usb.Init() == -1)
Serial.println("OSC did not start.");
delay(200);
if (!Hid.SetReportParser(0, &Joy))
ErrorMessage<uint8_t > (PSTR("SetReportParser"), 1);
Usb.Task();
USB HID Joystick .cpp
JoystickReportParser::JoystickReportParser(JoystickEvents *evt) :
joyEvents(evt),
oldHat(0xDE),
oldButtons(0) {
for (uint8_t i = 0; i < RPT_GEMEPAD_LEN; i++)
oldPad[i] = 0xD;
void JoystickReportParser::Parse(USBHID hid, bool is_rpt_id, uint8_t len, uint8_t buf) {
bool match = true;
// Checking if there are changes in report since the method was last called
if (buf[i] != oldPad[i]) {
match = false;
break;
// Calling Game Pad event handler
if (!match && joyEvents) {
joyEvents->OnGamePadChanged((const GamePadEventData*)buf);
for (uint8_t i = 0; i < RPT_GEMEPAD_LEN; i++) oldPad[i] = buf[i];
uint8_t hat = (buf[5] & 0xF);
// Calling Hat Switch event handler
if (hat != oldHat && joyEvents) {
joyEvents->OnHatSwitch(hat);
oldHat = hat;
uint16_t buttons = (0x0000 | buf[6]);
buttons <<= 4;
buttons |= (buf[5] >> 4);
uint16_t changes = (buttons ^ oldButtons);
// Calling Button Event Handler for every button changed
if (changes) {
for (uint8_t i = 0; i < 0x0C; i++) {
uint16_t mask = (0x0001 << i);
if (((mask & changes) > 0) && joyEvents) {
if ((buttons & mask) > 0)
joyEvents->OnButtonDn(i + 1);
else
joyEvents->OnButtonUp(i + 1);
oldButtons = buttons;
void JoystickEvents::OnGamePadChanged(const GamePadEventData *evt) {
Serial.print("X1: ");
PrintHex<uint8_t > (evt->X, 0x80);
Serial.print("\tY1: ");
PrintHex<uint8_t > (evt->Y, 0x80);
Serial.print("\tX2: ");
PrintHex<uint8_t > (evt->Z1, 0x80);
Serial.print("\tY2: ");
PrintHex<uint8_t > (evt->Z2, 0x80);
Serial.print("\tRz: ");
PrintHex<uint8_t > (evt->Rz, 0x80);
Serial.println("");
void JoystickEvents::OnHatSwitch(uint8_t hat) {
Serial.print("Hat Switch: ");
PrintHex<uint8_t > (hat, 0x80);
Serial.println("");
void JoystickEvents::OnButtonUp(uint8_t but_id) {
Serial.print("Up: ");
Serial.println(but_id, DEC);
void JoystickEvents::OnButtonDn(uint8_t but_id) {
Serial.print("Dn: ");
USB HID Joystick .h
#if !defined(__HIDJOYSTICKRPTPARSER_H__)
#define __HIDJOYSTICKRPTPARSER_H__
#include <usbhid.h>
struct GamePadEventData {
uint8_t X, Y, Z1, Z2, Rz;
class JoystickEvents {
public:
virtual void OnGamePadChanged(const GamePadEventData *evt);
virtual void OnHatSwitch(uint8_t hat);
virtual void OnButtonUp(uint8_t but_id);
virtual void OnButtonDn(uint8_t but_id);
#define RPT_GEMEPAD_LEN 5
class JoystickReportParser : public HIDReportParser {
JoystickEvents *joyEvents;
uint8_t oldPad[RPT_GEMEPAD_LEN];
uint8_t oldHat;
uint16_t oldButtons;
public:
JoystickReportParser(JoystickEvents *evt);
virtual void Parse(USBHID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf);
#endif // HIDJOYSTICKRPTPARSER_H
Edit of the current problem: (This was fixed with a bit of trial and error in the packed struct)
X: 512 Y: 512 Hat Switch: 0 Twist: 768 Slider: 108 Buttons A: 0 Buttons B: 0
X: 512 Y: 512 Hat Switch: 0 Twist: 256 Slider: 108 Buttons A: 0 Buttons B: 0
Edit for if statement issue: Below is a section of the what my issue pretty much goes down to. Now, I am assuming here that structs act in a similar way to dictionaries in python which I think is a massive simplification as they also seem to work as a class? Anyway, I was working on a way to have a first struct with the data for a specific joystick in, then using the data from that first to fill the second that will be used multiple times in the code but I think that is a worse method then what I have below and I couldn't get it to work anyway.
.cpp
#include "le3dp_rptparser.h"
#include <usbhid.h>
struct LogitechGamePro
union { //axes and hut switch
uint32_t axes;
struct {
uint32_t x : 10;
uint32_t y : 10;
uint32_t twist : 9;
uint32_t slider : 10;
uint8_t hat;
uint8_t buttons_a;
uint8_t buttons_b;
uint32_t axes;
struct {
uint32_t x : 10;
uint32_t y : 10;
uint32_t twist : 9;
uint8_t hat;
uint8_t buttons_a;
uint8_t buttons_b;
joyEvents(evt)
bool match = true;
for (uint8_t i=0; i<RPT_GAMEPAD_LEN; i++) {
if( buf[i] != oldPad[i] ) {
match = false;
break;
for (uint8_t i=0; i<RPT_GAMEPAD_LEN; i++) oldPad[i] = buf[i];
Serial.print("X: ");
PrintHex<uint16_t>(evt->x, 0x80);
Serial.print(" Y: ");
PrintHex<uint16_t>(evt->y, 0x80);
Serial.print(" Hat Switch: ");
PrintHex<uint8_t>(evt->hat, 0x80);
Serial.print(" Twist: ");
PrintHex<uint8_t>(evt->twist, 0x80);
Serial.print(" Slider: ");
PrintHex<uint8_t>(evt->slider, 0x80);
Serial.print(" Buttons A: ");
PrintHex<uint8_t>(evt->buttons_a, 0x80);
Serial.print(" Buttons B: ");
PrintHex<uint8_t>(evt->buttons_b, 0x80);
Serial.println("");
.h
#include <usbhid.h>
struct GamePadEventData {};
struct ST290 {};
struct LogitechGamePro {};
public:
#define RPT_GAMEPAD_LEN sizeof(GamePadEventData)/sizeof(uint8_t)
uint8_t oldPad[RPT_GAMEPAD_LEN];
public:
Error from Example code 2:
sketch\le3dp_rptparser.cpp: In member function 'virtual void JoystickReportParser::Parse(USBHID*, bool, uint8_t, uint8_t*)':
le3dp_rptparser.cpp:36:54: error: no matching function for call to 'JoystickEvents::OnGamePadChanged(GamePadEventData&)'
joyEvents->OnGamePadChanged(currentValues);
In file included from sketch\le3dp_rptparser.cpp:1:0:
sketch\le3dp_rptparser.h:43:15: note: candidate: virtual void JoystickEvents::OnGamePadChanged(const GamePadEventData*)
sketch\le3dp_rptparser.h:43:15: note: no known conversion for argument 1 from 'GamePadEventData' to 'const GamePadEventData*'
sketch\le3dp_rptparser.cpp: At global scope:
le3dp_rptparser.cpp:46:6: error: prototype for 'void JoystickEvents::OnGamePadChanged(GamePadEventData*)' does not match any in class 'JoystickEvents'
void JoystickEvents::OnGamePadChanged(GamePadEventData *evt)
le3dp_rptparser.h:43:15: error: candidate is: virtual void JoystickEvents::OnGamePadChanged(const GamePadEventData*)
exit status 1
