I'm trying to write a program for AVR Atmel 328 chip on Arduino Nano board that will allow me to send machine code instructions to the chip over a serial line, run/execute them on the chip, and interrogate the results by reading chip memory and sending the contents back over the serial line. This is the genesis of the idea: 3-instruction Forth by Frank Sergeant.
The remote-store and remote-fetch instructions appear to be working fine, but I've not been able to get the remote-call instruction (XCALL() function) to work. The approach I've taken is to coerce a 16-bit address into a subroutine by casting it as a function pointer.
Below is the code that is running on the Arduino Nano (compiled in the Arduino IDE and uploaded using the USB cable via the bootloader)
Any insight would be greatly appreciated! (I can add diassembled code, my remote instructions etc, if that helps).
Thanks in advance!
// Remote serial development platform for machine coding ArduinoNano/ATmel328, AKE, Jun 9, 2020
// global variables
unsigned char byt; // command token from host
unsigned char mem[255]; // memory window under programmatic control
unsigned char dat; // data byte from host
unsigned char adr_lo; // address from host, low byte first
unsigned char adr_hi;
unsigned short adr; // combined 16-bit address
typedef void (*GeneralFunction)(); // template to call memory address (as a subroutine)
Serial.begin(9600); // Turn UART serial protocol ON for comms with host PC
Serial.write(0xFF); // magic number to verify transmission
Serial.write(0xFE);
Serial.write((int) mem); // Informs you of the writeable address space available (LSB, MSB) for tethered memory access
Serial.write((int) mem>>8);
char get_byte(void) {
while (!(Serial.available()>0)) { delay(50); }
return Serial.read();
short get_adr(void) {
adr_lo=get_byte();
adr_hi=get_byte();
return ( (short)adr_hi<<8 ) | (short)adr_lo;
void xstore() { // Instruction 1 = xstore(data,adr_lo,adr_hi). Store byte from host at indicated address in target.
dat=get_byte();
adr=get_adr();
(char )adr=dat;
void xfetch() { // Instruction 2 = xfetch(adr_lo,adr_hi). Read byte from target memory and return to host.
adr=get_adr();
dat=(char )adr;
Serial.write(dat);
void xcall() { // Instruction 3 = xcall(adr_lo,adr_hi). Execute subroutine in target memory from indicated address.
// WARNING! User must have stored RET instruction to send control back to serial monitor.
adr=get_adr();
GeneralFunction fGf=adr;
fGf;
byt = get_byte(); // user specified instruction token (1,2,3)
if(byt == 0x01 ) { xstore(); }
else if (byt == 0x02) { xfetch(); }
else if (byt == 0x3 ) { xcall(); } // else ignore any other serial inputs
