Got this when uploading (no programmer) to a MkrZero.
I had downloaded the board's toolset via the IDE earlier, and uploading smaller sketches worked fine. On a larger, more complex project, got this:
Sketch uses 31000 bytes (11%) of program storage space. Maximum is 262144 bytes.
Atmel SMART device 0x10010005 found
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Dec 20 2016 15:36:46
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : none
Security : false
Boot Flash : true
BOD : false
BOR : false
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.800 seconds
Write 31336 bytes to flash (490 pages)
[=== ] 13% (64/490 pages)
[======= ] 26% (128/490 pages)
[=========== ] 39% (192/490 pages)
[=============== ] 52% (256/490 pages)
[=================== ] 65% (320/490 pages)
[======================= ] 78% (384/490 pages)
[=========================== ] 91% (448/490 pages)
[==============================] 100% (490/490 pages)
done in 0.234 seconds
Verify 31336 bytes of flash with checksum.
Verify successful
done in 0.075 seconds
CPU reset.
It sounds like it reset the chip completely... and Windows no longer sees a COM port from it via USB. I've tried: * The click and double-click on the board's reset button, including at the start of a new upload of a simple sketch * Restarting the Windows machine * Looking at device manager to see if any COM ports show up, even temporarily * Same cable, same computer, different MKRZero - works
Main question: What could there be in the project to have caused the compiler/loader to do this? This is the 2nd time this project has triggered a reflash. It does use the EEPROM API by A. Christian, but I've been able to use that before without this result.
2nd: Any other ways to recover the board?
Thank you for any guidance.
