I am running the following code on my ESP8266 (AI-Thinker ESP8266MOD).
I send an HTTP GET request and a pin is set to high for a 1/2 second.
However, after some time (sometimes 1hr, 2hrs, 12hrs, totally random), it stops responding to HTTP requests. I think it might be because of heap fragmentation due to the String objects I'm using.
Questions:
How can I replace the request (in loop()) and s and text (in GenerateResponse()) objects with char arrays? After I replace the String objects with char arrays, how can I use the indexOf() method and + operator on the char arrays?
Will this approach help with heap fragmentation?
Is it possible to find out if heap fragmentation is the problem?
#include <ESP8266WiFi.h>
const char* ssid = "myWifi";
const char* wifiPassword = "y76ggS";
const char* passwordToOpenDoor = "/81"; //password should begin with a slash
const int doorPin = 5;
WiFiServer server(301); //Pick any port number you like
WiFiClient client;
  Serial.begin(115200);
  delay(10);
  Serial.println(WiFi.localIP());
  pinMode(doorPin, OUTPUT);
  digitalWrite(doorPin, 0);
  Serial.println();
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, wifiPassword);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  server.begin();
  Serial.println("Server started. Diagnostics info:");
  client = server.available();
  if (!client) {
    return;
  while(!client.available()){
    delay(1);
  String request = client.readStringUntil('\r');
  client.flush();
  Serial.println(request);
  if (request.indexOf(passwordToOpenDoor) != -1) { //Is password correct?
    GenerateResponse("Password is correct");
    OpenDoor();
  //Got a GET request and it wasn't the favicon.ico request, must have been a bad password:
  else if (request.indexOf("favicon.ico") == -1) {
    GenerateResponse("Password is incorrect.");
void OpenDoor() {
  digitalWrite(doorPin, 1);
  delay(500);
void GenerateResponse(String text) {
  Serial.println(text);
  String s = "HTTP/1.1 200 OK\r\n";
  s += "Content-Type: text/html\r\n\r\n";
  s += "<!DOCTYPE HTML>\r\n<html>\r\n";
  s += "<br><h1><b>" + text + "</b></h1>";
  s += "</html>\n";
  client.flush();
  client.print(s);
  delay(1);
David Klempfner
  • 167
So here is code to get you started:
myMessageArray [256] = {'\0'}; // Define global array large enough and zero terminate
the + method is replaced by
strcpy (myMessageArray, "Text to Add");
// Initializes the myMessageArray starts at index 0
strcat (myMessageArray, "More text to Add");
// Appends to the myMessageArray starts at current index
converting numeric values to chars:
uint_16_t myNumberValue  = 31253;
char numBuffer [16] = {'\0'}; // Helper buffer for conversions
itoa (myNumberValue,numBuffer,10);  // converts an integer to a base 10 (decimal) char
itoa (myNumberValue,numBuffer,2);  // converts an integer to a base 2 (binary) char
itoa (myNuberValue,numBuffer,16);  // converts an integer to a base 16 (hex) char
itoa initilizes a char array so we need the helper array:
strcat (myMessageArray, numBuffer);
to convert float we use
dtostrf(floatVariable, StringLengthIncDecimalPoint, numVarsAfterDecimal, numBuffer);
to convert chars back to int use
int16_t myIntVar = atoi(numBuffer);
to convert chars back to floats use
float myFloatVar = atof(numBuffer, decimalsToShow); // using just atof(numBuffer)
gives you standard x.XX only 2 decimals
A working IndexOf for char arrays:
    \brief Finds the index of the given value in the array starting at the given index
    \author codebreaker007
    \param [in] targetArray the array to search through for the char
    \param [in] valueToFind the value to find
    \param [in] startIndex the index to start searching at
    \return the index of the value within the array
    \details This method returns INDEX_NOT_FOUND^(-1) for a null input array.
        A negative startIndex is treated as zero. A startIndex larger than the array
        length will return INDEX_NOT_FOUND(-1)
int8_t indexOf(char* targetArray, char valueToFind, uint16_t startIndex = 0) {
  if (targetArray == NULL) {
    return INDEX_NOT_FOUND;
  if (startIndex <= 0) {
    startIndex = 0;
  for (uint16_t i = startIndex; i < strlen(targetArray); i++) {
    if (valueToFind == targetArray[i]) {
      return i;
To compare char arrays you should look into the strcmp function and if you want to checkthe first n char tomatchyou use:
if (strncmp(myMessageArray , "POST", 4 ) == 0) {
// compares the first 4 chars if it matches = 0, see details in the arduino doku
Hope this comprehensive intro to char arrays helps you for your current and future projects. How to find out - convert to char arrays and if its runnibg stable that was it. Before that conversion you can never rule out String class as culprit.
Codebreaker007
  • 1,331
You already received good answer about some general ideas for replacing String objects with C strings. Here I will try to add some more tricks more specifically targeted to your actual situation.
I can see two places in your program where the use of String shines by its convenience, and replacing it with C strings will require some effort. The first is the use of Stream::readStringUntil(char) for getting the first request line. Here I see no better option (see edit below) than reading the stream one character at a time, and putting those characters into an array:
const size_t input_buffer_length = 256;
// Read a line of text up to the first '\r'.
// Returns a NUL-terminated string, without the final '\r',
// into a statically allocated buffer.
// Warning: this never times out.
const char *readline(Stream &input)
  static char buffer[input_buffer_length];
  size_t pos = 0;  // writing position within the buffer
  int c;           // current character
  while ((c = input.read()) != '\r') {
    if (c >= 0 && pos < sizeof buffer - 1) {
      buffer[pos++] = c;
  buffer[pos] = '\0';  // terminate the string
  return buffer;
You would use it like this:
const char *request = readline(client);
For more robustness, you may want to add a timeout. Note also that this implementation is no reentrant, as it uses a static buffer. This is not an issue for your use case.
Edit: As noted by hcheung in a comment, you do not need to implement this readline() function, as you can use Stream::readBytesUntil(), which handles the timeout and is provided by the Arduino core:
client.readBytesUntil('\r', buffer, input_buffer_length);
The other place is the usage of String::operator+=(const char *) for generating the response. Here I would advice you against using strcat() or strncat(): these will require extra memory to store the concatenated string which you probably do not need. Instead, you can simply print() the pieces one by one:
void GenerateResponse(const char *text) {
  client.println("HTTP/1.1 200 OK");
  client.println("Content-Type: text/html");
  client.println();
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.print("<br><h1><b>");
  client.print(text);
  client.println("</b></h1></html>");
  client.flush();
  delay(1);
Alternatively, you can make use of the implicit concatenation of string literals in order to reduce the number of calls to client.print():
  client.print(
      "Content-Type: text/html\r\n"
      "\r\n"
      "<!DOCTYPE HTML>\r\n"
      "<html>\r\n"
      "<br><h1><b>"
  client.print(text);
  client.print("</b></h1></html>\r\n");
  client.flush();
  delay(1);
Edgar Bonet
  • 45,094
  • 81
You asked: "After I replace the String objects with char arrays, how can I use the indexOf() method and + operator on the char arrays?"
Short answer: You can't. If you want to use C strings (aka arrays of char), you'll have to use C string functions.
The String methods operate on String objects. The common wisdom is to avoid the String class entirely since it relies on heap memory, and Arduinos are far, far too memory-starved to be able to use a class like String which creates temporary objects on the heap.
Duncan C
  • 5,752
  • 30
