The following script prints everything fine, it recognizes integers from the serial port, but cannot recognize characters. The if statement does not work with characters. I have tried both == and === in the if statement
var SerialPort = require('serialport')
var Readline = SerialPort.parsers.Readline
var serialPort = new SerialPort('/dev/ttyAMA0', {//ttyAMA0
baudRate: 9600
var parser = new Readline()
serialPort.pipe(parser)
parser.on('data', function (data) {
if(data === 'c'){/// c is not recognized
console.log('data received: ' + data)
serialPort.on('open', function () {
console.log('Communication is on!')
The Arduino code is as follows:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13); // RX, TX
int x = 0;
int y = -30000;
int z = 0;
String data;
char command = 'q';
int left = 0;
int right = 0;
int left_pwm = 0;
int right_pwm = 0;
mySerial.begin(9600); // opens serial port, sets data rate to 9600 bps
Serial.begin(9600);
void loop() {//map and compass data
if (y==30000) {
mySerial.println('c');
delay(5);
mySerial.println(299);
delay(5);
z = -25000;
if(z==30000){
mySerial.println('lon');
delay(5);
mySerial.println(529);
delay(5);
mySerial.println('lat');
delay(5);
mySerial.println(522);
y = -30000;
y++; z++;
if (!mySerial.available()) {
return;
data = mySerial.readString();
sscanf(data.c_str(), "%c%01d%01d%03d,%03d", &command, &left, &right, &left_pwm, &right_pwm);
if (command == 'n') { // we got a navigation command
// update the GPIO accordingly, this only happens once after a new 'n' command has been received
Serial.print(command);
Serial.print(left);
Serial.print(right);
Serial.print(left_pwm);
Serial.print(",");
Serial.println(right_pwm);
}////end loop
