Good day.
The NodeMCu successfully connected to mobile hotspot when i didn't put any others codes except the Wifibegin etc.
Howveer when I include some codes for temparature sensor, it keeps on connecting whereas the everything else including the SSID, password remain the same.
Below are my codes, I tried many, I mean I tried almost everything possible(that's stated in forums), read forums after forum. Please let me know if I missed something out here.
Thanks!
PS: i attached my codes here
#include <ESP8266WiFi.h>
#include <WifiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
/* Wi-Fi setting connect to your smartphone Wi-Fi hotspot */
const char *ssid = "Thanks";
const char *password = "​For reading";
/* Variable for taking out LM35 value */
String tempValue;
int analogValue;
int tempPin = A0;
float milliVolts;
float celcius;
/* Variable for sending data to server */
String postData;
int httpCode;
String payload;
void setup(){
//delay(1000);
Serial.begin(115200);
WiFi.begin(ssid,password);
Serial.println("");
Serial.println("Connecting");
/* If Wi-Fi hotspot is not found, show ..... in serial monitor */
while(WiFi.status()!=WL_CONNECTED){
delay(500);
Serial.println(".");
/* If Wi-Fi hotspot is found, show IP address in serial monitor */
Serial.println("");
Serial.println("Connected to ");
Serial.println(ssid);
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void loop(){
/* Getting value from LM35 */
delay(1000);
analogValue = analogRead(tempPin);
milliVolts = (analogValue/1024.0)*3300;
celcius = milliVolts/10;
tempValue = String(celcius);
Serial.println(tempValue);
/* Sending LM35 value to server */
HTTPClient http;
postData = "tempValue=" + tempValue;
http.begin("http://xxx.xxx.xx.xxx/dbInsert.php");
http.addHeader("Content-Type","application/x-www-form-urlencoded");
httpCode = http.POST(postData);
payload = http.getString();
Serial.println(httpCode); //Print HTTP return code
Serial.println(payload); //Print request response payload
http.end();
mocha234
Get rid of the delay - this STOPS processing for five seconds, not really what you want in a wifi scenario - some routers might disconnect you in this time if no pingbackis are coming
If you need a 5 second- non blocking break for your routines look at this example
ArduinoIDE -> examples -> 2 Digital -> blinkwithoutdelay.
For further assistance copy and paste your code in code tags and not as a picture.
Codebreaker007
  • 1,331
