I'm trying out the AP mode of the device, where it can serve as its own server. Most of the tutorials have been loading the html from the SD card. I can do the same, but the bootstrap of the website is not working. It just loads the basic version of the website. How can I fix this?
APMode.ino
#include <SPI.h>
#include <SD.h>
#include <WiFiNINA.h>
#define WEBHTM "SERVER/index.htm"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h char ssid[] = "MKRTEST"; // your network SSID (name) char pass[] = "PASS"; // your network password (use for WPA, or use as key for WEP) int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS; WiFiServer server(80);
File webFile;
//Initialize serial and wait for port to open:
Serial.begin(9600);
while (!Serial);
Serial.println(&quot;Access Point Web Server&quot;);
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println(&quot;Communication with WiFi module failed!&quot;);
// don't continue
while (true);
if(!SD.begin(4))
    Serial.println(&quot;SD card not found!&quot;);
    while(1);
if (!SD.exists(WEBHTM))
    Serial.println(&quot;missing index.htm!&quot;);
    while(1);
String fv = WiFi.firmwareVersion();
if (fv &lt; WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println(&quot;Please upgrade the firmware&quot;);
// by default the local IP address of will be 192.168.4.1
// you can override it with the following:
// WiFi.config(IPAddress(10, 0, 0, 1));
// print the network name (SSID);
Serial.print(&quot;Creating access point named: &quot;);
Serial.println(ssid);
// Create open network. Change this line if you want to create an WEP network:
status = WiFi.beginAP(ssid);
if (status != WL_AP_LISTENING) {
Serial.println(&quot;Creating access point failed&quot;);
// don't continue
while (true);
// wait 10 seconds for connection:
delay(10000);
// start the web server on port 80
server.begin();
// you're connected now, so print out the status
printWiFiStatus();
void loop() { // compare the previous status to the current status if (status != WiFi.status()) { // it has changed update the variable status = WiFi.status();
if (status == WL_AP_CONNECTED) {
  // a device has connected to the AP
  Serial.println(&quot;Device connected to AP&quot;);
} else {
  // a device has disconnected from the AP, and we are back in listening mode
  Serial.println(&quot;Device disconnected from AP&quot;);
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client, Serial.println("new client"); // print a message out the serial port String currentLine = ""; // make a String to hold incoming data from the client while (client.connected()) { // loop while the client's connected if (client.available()) { // if there's bytes to read from the client, char c = client.read(); // read a byte, then Serial.write(c); // print it out the serial monitor if (c == '\n') { // if the byte is a newline character
      // if the current line is blank, you got two newline characters in a row.
      // that's the end of the client HTTP request, so send a response:
      if (currentLine.length() == 0) {
        // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
        // and a content-type so the client knows what's coming, then a blank line:
        client.println(&quot;HTTP/1.1 200 OK&quot;);
        client.println(&quot;Content-type:text/html&quot;);
        client.println();
        webFile = SD.open(WEBHTM);
        if (webFile)
          while (webFile.available())
            client.write(webFile.read());
          webFile.close();
        // The HTTP response ends with another blank line:
        client.println();
        // break out of the while loop:
        break;
      else {      // if you got a newline, then clear currentLine:
        currentLine = &quot;&quot;;
    else if (c != '\r') {    // if you got anything else but a carriage return character,
      currentLine += c;      // add it to the end of the currentLine
    if (currentLine.endsWith(&quot;POST /enterCredentials&quot;)) {
    //   digitalWrite(led, HIGH);               // GET /H turns the LED on
    Serial.println(&quot;Hello there!&quot;);
// close the connection:
client.stop();
Serial.println(&quot;client disconnected&quot;);
void printWiFiStatus() { // print the SSID of the network you're attached to: Serial.print("SSID: "); Serial.println(WiFi.SSID());
// print your WiFi shield's IP address: IPAddress ip = WiFi.localIP(); Serial.print("IP Address: "); Serial.println(ip);
// print where to go in a browser: Serial.print("To see this page in action, open a browser to http://"); Serial.println(ip);
index.htm
<!DOCTYPE html>
<html lang="en">
<head>
  <title>LPS Server</title>
  <meta charset="utf-8">
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/4.4.1/css/bootstrap.min.css">
</head>
<body>
<div class="jumbotron text-center" style="margin-bottom:0"> <h1>Low Power Sensor (LPS) Server</h1> </div>
<div class="container" style="margin-top:30px" id="WifiDetails"> <h3>Please enter needed Credentials</h3> <form action="/enterCredentials.htm" method="post"><label for="SSID">SSID:</label><input type="text" class="form-control" name="SSID"><label for="PASS">PASS:</label><input type="password" class="form-control" name="PASS"><label for="BROKER">Broker/Host:</label><input type="text" class="form-control" name="BROKER"><label for="DEVID">Device ID:</label> <input type="text" class="form-control" name="DEVID"><input type="hidden" name="eof" value="#EOF"><br><button type="submit" class="btn btn-primary btn-block" value="Submit">SUBMIT</button></form>
</div>
<div class="jumbotron text-center" style="margin-bottom:0"><p>All Rights Reserved 2020</p></div></body> </html>
Dorokun192
