My hardware is 4 potentiometers connected to Arduino Analog 0-3, the output is an RGB led driver connected to Digital outputs 9,10,11. The output channels provide access to PWM control of those pins. So idea is the color and intensity can be controlled by the Arduino. I wrote a simple Sketch that reads the potentiometers and then outputs PWM to the RGB driver circuitry. This works great! So the hardware is working! Now comes the last potentiometer...
I want to make the last potentiometer a "mode select" control. It would function like this: If the last potentiometer (Pot4) is turned down all the way, then all lights are off. If the level is turned up a little, the Arduino then controls the RGB channels via Pots 1, 2 & 3. If Pot4 is turned up to just past halfway, the sketch enters a "strobe flash pattern" pulsing all channels on and off. And if the mode control Pot4 is turned up all the way, Arduino turns on all RGB channels.
How do I implement? Mode selection via a potentiometer?
Philip Allgaier
  • 245
user608
Since you already know how to hook up a pot and read it's value, it's quite simple. You already have it hooked up in a voltage divider configuration and are getting a 10 bit (0-1023) value using analogRead(), you just need to decide what to do with it.
Assume potVal has the value of the pot.;
if (potVal < 256) {
    // Pot is one quarter turn or less
} else if (potVal < 512) {
    // Pot is between 256 and 512, so its more than quarter but less than half
} else if (potVal < 768) {
    // Pot is between half and 3/4ths of the way there
} else {
    // Pot is greater than 3/4 of it's full range
So I have broken it down into four quadrants for you, but you can do it however you like.
sachleen
  • 7,565
  • 40
  • 57
It would be relatively simple to do a threshold test on analogRead() to switch modes (e.g. if the value is above 512 (analogRead() gives values between 0-1023) then you switch modes (probably with a boolean variable that you can then use to decide whether to strobe the LEDs).
WineSoaked
  • 111
