It has already been asked how many clients can connect to an ESP32 AP, but the answer is far from clear; the best one is from a year and half ago (ESP32 AP max connections: 4 or 10?) :
The answer is as clear as any other EspressIf configuration data, it is 4 or maybe 5, or 8, or 12, 16 or even 20 (the same as a ESP8266!)
As I'm trying to move a project from the ESP8266 because it does not have enough AP connections, two questions can be asked :
  1. what is the maximum number of AP connections supported by the 4.0 ESP-IDF framework ?
  2. can it be increased in any way ?
Thank you.
stefanu
  • 131
After some extensive testing with several modules (not just blindly trusting the documentation), here's what I found.
Short answer : maximum 10 AP connections for the ESP32 running ESP-IDF 4.0 (updated around 1st of march 2020), and no, it can't be increased (easily).
Details :
  • The maximum number of AP connections is defined somewhere in libnet80211, and can't be modified since I have no access to the source code.
  • when the 11th station tries to connect, libnet80211 prints I (39682043) wifi: max connection, deauth!, more or less like the ESP8266 for the 5th station
  • Changine the ESP_WIFI_MAX_CONN_NUM (defined in esp_wifi_types.h:258) from 10 to anything else ends up in unpredictable behavior (I'm labelling this as unpredictable since without the libnet80211 code, it can't be reliably assessed).
I'm not giving up on increasing the number of stations yet, so maybe there'll be an update to this answer.
stefanu
  • 131
According to the documentation:
uint8_t max_connection
Max number of stations allowed to connect in, default 4, max 4
The WiFi interface and AP can support up to 10 connections in its internal structures, but that is only practical for WiFi Mesh usage (which doesn't use all 7 layers of the ISO model), and for actual WiFi station connections, which entails the allocation of far more resources (IP addresses, ARP tables, etc) only a maximum of 4 are supported.
If you need more connections I suggest you invest in a real access point / router which can deal with the network management for you (i.e., an access point or router which can do the DHCP and other networking housekeeping for you, leaving your ESP32 free to be a simple station).
Majenko
  • 105,851
  • 82
  • 139
