I know this is a common question but the truth is every code is different. Sometimes it's hard to apply the concept to your code, it does not work. So please help me. What is wrong with this code? I got it from GitHub. I'm trying to compile it first before I can do a little modification, it sends temp and humidity data to ThingSpeak cloud servers.
#include <DHT.h> // Including library for dht
#include <ESP8266WiFi.h>
String api_key = "YOUR API KEY"; // Enter your Write API key from ThingSpeak
const char *ssid = "YOUR WIFI SSID"; // replace with your wifi ssid and wpa2 key
const char *pass = "YOUR WIFI PASSWORD";
const char* server = "api.thingspeak.com";
#define DHTPIN 1 // pin where the dht11 is connected
DHT dht;
WiFiClient client;
Serial.begin(115200);
delay(10);
pinMode(2, OUTPUT);
digitalWrite(2, 0);
Serial.println("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
int chk = DHT.read(DHTPIN);
float hum = DHT.humidity;
float temp = DHT.temperature;
if (isnan(hum) || isnan(temp)) {
Serial.println("Failed to read from DHT sensor!");
return;
if (client.connect(server, 80)) {
// "184.106.153.149" or api.thingspeak.com
String data_to_send = api_key;
data_to_send += "&field1=";
data_to_send += hum;
data_to_send += "&field2=";
data_to_send += temp;
data_to_send += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + api_key + "\n");
client.print("Content-Type: application/x-www-form-
urlencoded\n");
client.print("Content-Length: ");
client.print(data_to_send.length());
client.print("\n\n");
client.print(data_to_send);
delay(1000);
Serial.print("Temperature: ");
Serial.print(temp);
Serial.print(" degrees Celcius, Humidity: ");
Serial.print(hum);
Serial.println("%. Send to Thingspeak.");
client.stop();
Serial.println("Waiting...");
// ThingSpeak needs minimum 15 sec delay between updates, I've set it to 30 seconds
delay(10000);
When I compile I get this error,
Arduino: 1.8.10 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E
Module), 80 MHz, Flash,
Legacy (new can return nullptr), All SSL ciphers (most
compatible),
4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Users\Agent 96\Desktop\thingspeak\thingspeak.ino: In function 'void loop()':
thingspeak:37:20: error: expected primary-expression before '.' token
thingspeak:38:22: error: expected primary-expression before '.' token
thingspeak:39:23: error: expected primary-expression before '.' token
Multiple libraries were found for "DHT.h"
Used: C:\Users\Agent
Not used: C:\Users\Agent
Multiple libraries were found for "ESP8266WiFi.h"
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Please help, I'm kind of a beginner.
