I am doing a project, and I need an SD card. Everything worked well, but after a while when I read the SD card from my PC(Windows 10 64 bit, Intel Core), I found a file called eecfbba=.@aa. It's so big that it almost ate up one GB storage of my SD card. But when I tried to open it with notepad, notepad tells me that there is actually no such file, and asks me if I want to create it. I tried to delete it, but file explorer also told me there is no such file. What is it?
This is my code:
#include <ArduinoJson.h>
// Version 0.20.1.19.3.7:
// 2020/01/19, 16:10, button record test, 7th version.
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#include <Wire.h>
#include "RTClib.h"
//#include <string.h>
RTC_DS1307 rtc;
String strdoc;
char daysOfTheWeek[7][2] = {"su", "mo", "tu", "we", "th", "fr", "sa"};
#define SD_ChipSelectPin 10 // 如果使用 arduino nano 328 可使用Pin4
TMRpcm audio;
audio.speakerPin = 8;
Serial.begin(9600);
pinMode(25, INPUT_PULLUP);
pinMode(7, INPUT_PULLUP);
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running!");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
else
Serial.println("rtc started");
if (!SD.begin(SD_ChipSelectPin)) {
Serial.println("SD Fail");
return;
} else {
Serial.println("SD OK");
audio.setVolume(6);
audio.CSPin = SD_ChipSelectPin;
StaticJsonDocument<200> doc;
doc["sensor"] = "gps";
doc["time"] = 1351824120;
JsonArray data = doc.createNestedArray("data");
data.add(48.756080);
data.add(2.302038);
serializeJson(doc, strdoc);
bool isrecording = false;
bool recordButtonPressed()
return (digitalRead(25) == LOW);
bool playButtonPressed()
return (digitalRead(7) == LOW);
delay(200);
// Below is the formatted datetime.
DateTime now = rtc.now();
// Below is the serialized datetime.
String filename = (String)(now.unixtime() % 10000000) + ".j";
// Serial.println(filename);
if (recordButtonPressed())
if (!isrecording)
isrecording = true;
audio.startRecording("test.wav", 16000, A0);
Serial.println("stt");
else
Serial.println("stp");
audio.stopRecording("test.wav");
Serial.println("sdsad991===`=`");
if (playButtonPressed())
audio.play("test.wav");
Serial.println("ply");
String dataString = strdoc;
if (!isrecording)
File dataFile = SD.open(filename, FILE_WRITE);
if (!dataFile) {
Serial.println(F("Failed to create file"));
else
dataFile.println(dataString);
Serial.println("Wrote string.");
dataFile.close();
Serial.println("Closed file.");
/* Please ignore this line */
// // audio.play("test.wav"); break;audio.volume(1); break;audio.volume(0); break;audio.stopPlayback(); break;
P.S. I'm using Mega 2560, so MISO, MOSI, SCK and CS pins are different.(Which is 50,51,52,10).
Edit 2020/1/25, 14:15(Beijing Time) At 1/20 I have bigger problems. There are more and more big files. All of them are the same situation. For details, take a look at this photo(ignore selected files): Imgur or 咱们中国人上不去imgur,用这个:File-up(直接下载)
