I'm having an irritating situation with my Arduino Uno wifi rev2 board. I made an installation with an LCD, keypad and little servo motor. I first wrote the code for my regular Arduino Uno and everything worked fine. Now I migrated my installation to my new Arduino Uno wifi rev2 because I needed it to make a request. But the problem is when I try to upload my code to the wifi rev2 it gives me a compilation error. I tried to upload a blink test sketch to see if it would work and it did but somehow it doesn't want to compile this code:
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <Servo.h>
#include <Keypad.h>
LiquidCrystal_I2C lcd(0x27,16, 2);
Servo myservo;
const byte ROWS = 4;
const byte COLS = 3;
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
byte rowPins[ROWS] = {3, 4, 5, 6};
byte colPins[COLS] = {9, 8, 7};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
String value = "";
void setup(){
lcd.begin();
Serial.begin(9600);
myservo.attach(A0);
lcd.backlight();
//myservo.write(0);
void loop(){
lcd.clear();
char customKey = customKeypad.getKey(); // get the key pressed
value = value + String(customKey);
lcd.print("Geef bestelcode");
lcd.setCursor(0,1);
lcd.print("in: " + value);
// char customKey = customKeypad.getKey(); // get the key pressed
if(customKey=='#'){
if(value == "1234#"){
myservo.write(0);
// int pos = value.toInt(); // convert value to int
// myservo.write(pos); // rotate the servo
else{exit;} // clear the string
if(customKey=='*'){ // 'D' works as "enter"
myservo.write(90); // rotate the servo
value = ""; // clear the string
if(customKey && customKey!= '#'){ // if the key pressed is not 'D'
value = value + String(customKey); // concatenate the number to value
//Serial.println(value);
delay(175);
The output of my error console :
In file included from C:\Users\TONES-PC\Documents\Arduino\sketch_dec15a_parcelbox_tester\sketch_dec15a_parcelbox_tester.ino:5:0:
C:\Users\TONES-PC\Documents\Arduino\libraries\Keypad/Keypad.h: In member function 'virtual void Keypad::pin_write(byte, boolean)':
C:\Users\TONES-PC\Documents\Arduino\libraries\Keypad/Keypad.h:88:81: error: cannot convert 'boolean {aka bool}' to 'PinStatus' for argument '2' to 'void digitalWrite(pin_size_t, PinStatus)'
virtual void pin_write(byte pinNum, boolean level) { digitalWrite(pinNum, level); }
Several libraries found for "Wire.h"
used: C:\Users\TONES-PC\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.5\libraries\Wire
Several libraries found for "LiquidCrystal_I2C.h"
used: C:\Users\TONES-PC\Documents\Arduino\libraries\Arduino-LiquidCrystal-I2C-library-master
Several libraries found for "Servo.h"
used: C:\Program
Several libraries found for "Keypad.h"
used: C:\Users\TONES-PC\Documents\Arduino\libraries\Keypad
exit status 1
Error with compiling for board Arduino Uno WiFi Rev2
Any thoughts on how to solve this?
