const uint8_t OUTPUT_PIN = 3;  // = OC2B
const uint8_t PERIOD = 9;      // 9 CPU cycles ~ 1.778 MHz
void setup()
    pinMode(OUTPUT_PIN, OUTPUT);
    TCCR2B = 0;           // stop timer
    TCNT2  = 0;           // reset timer
    TCCR2A = _BV(COM2B1)  // non-inverting PWM on OC2B
           | _BV(WGM20)   // fast PWM mode, TOP = OCR2A
           | _BV(WGM21);  // ...ditto
    TCCR2B = _BV(WGM22);  // ...ditto
    OCR2A = PERIOD - 1;
    OCR2B = PERIOD/2 - 1;
void soundBuzzer() {
    TCCR2B |= _BV(CS20);  // F_CPU / 1
void silenceBuzzer() {
    TCCR2B &= ~_BV(CS20);
    TCNT2 = 0;
I got it from here, look down to the answers
This program supposed to generate a square-wave of frequency around 1.7MHz but it is not working for me. I have tried the simulation on Proteus 8 and there is no output. Only one error shows during the compilation which is the 'loop' function is missing, I have added one and still there is no output. Please somebody help me.
Arjun
In the setup there is some settings for timer2, but no change of prescaller, so the timer stays stopped.
Obviously it was started by calling soundBuzzer() somewhere in code. But this function name is now kinda misleading. Just set prescaller in the setup and it should be working.
KIIV
  • 4,907
