Here's my Code so far:
Serial.begin(9600);
float a;
float angle;
int setpoint;
a = analogRead(A1);
angle = map(a, 0, 1023, 0, 180);
if ( (angle>0) && (angle<70) )
setpoint=50;
if ( (angle>70) && (angle<110) )
setpoint=90;
if ( (angle>110) && (angle<180) )
setpoint=130;
Serial.print(setpoint);
Serial.print(",");
Serial.println(angle);
I'm using an Arduino Genuino.
How can I get the servo motor to move to the setpoints and stop when the angle is between the eligible range?
just wanted to update showing how i solved this problem using the following code.
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
Serial.begin(9600);
float a;
float b;
float desired_angle;
float actual_angle;
float error;
float motor;
float setpoint;
a=analogRead(A1);
desired_angle=map(a,0,1023,0,180);
b=analogRead(A2);
actual_angle=map(b,125,920,0,180);
if ( (desired_angle>0) && (desired_angle<70) )
setpoint=50;
if ( (desired_angle>70) && (desired_angle<110) )
setpoint=90;
if ( (desired_angle>110) && (desired_angle<180) )
setpoint=130;
error=(setpoint-actual_angle);
motor=desired_angle/270*255;
if (error>0)
digitalWrite(5,LOW);
analogWrite(6,motor);
if (error<0)
digitalWrite(6,LOW);
analogWrite(5,-1*motor);
Serial.print(actual_angle);
Serial.print(",");
Serial.println(setpoint);
