My code initializes, the header (the ID; Value string) for the .csv file gets saved, but the dataString which is the most important part doesnt save to the .csv file.
I get an arraypointer to the start of the array. I dont have much experience with pointers but i dont get any errors.
The best solution would be if i could put everything into the "write matrix to SD"-function. Anyone has an idea? I am just dumbfounded because everything works perfectly without the arraypointer and i dont know what to try.
My setup()
Serial.begin(115200);
p_EKG_state_1 = &EKG_state_1;
pinMode(CS_Pin, OUTPUT);
if(!SD.begin(CS_Pin))
Serial.println("Card failed or not present");
EKG_data_transmision.matrixData = SD.open("/data.csv", FILE_APPEND); //erstelle data.csv datei
if(EKG_data_transmision.matrixData)
String header = "ID; Value;";
EKG_data_transmision.matrixData.println(header);
EKG_data_transmision.matrixData.close();
Serial.println(header);
Serial.println("card init sucess");
else
Serial.println("Couldnt open vector data file");
//Serial.println(ESP.getFreeHeap());
pinMode(LED_BUILTIN, OUTPUT); // TEST OUTPUT LED PIN
pinMode(btn_modus.PIN, INPUT_PULLUP); // MODUSAUSWAHL TASTER
attachInterrupt(btn_modus.PIN, isr, FALLING); // MODUS TASTER hört auf fallende Flanke und führt dann Funktion isr aus
WiFi.begin(ssid, password); // Verbinde mit WLAN
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer); // initialisiere Zeit variablen
EKG_state_1.set_state(1);
My function that writes the matrix/arraypointer to the SD
bool EKG_data_transmision::write_matrix_to_SD(unsigned short *array_pointer) // Übertrage , unsigned short id
return 1;
if(matrixData)
//look if data.csv exists
while(matrix_coloum < 3071)
if(matrix_coloum == 1024 || matrix_coloum == 2048)
header = "ID; Value;\n";
dataString = String(matrix_coloum) + ";" + String(*array_pointer) + "\n";
matrixData.println(dataString);
Serial.println("This is datastring:");
Serial.println(dataString);
array_pointer++;
matrix_coloum++;
else{
Serial.println("Error writing to file !");
matrixData.close(); // close the file
return 0;
My class with all the inits
class EKG_data_transmision
private:
String dataString;
String header;
unsigned short matrix_coloum = 0;
public:
EKG_data_transmision();
File matrixData;
//Definiere Funktionen:
bool write_matrix_to_SD(unsigned short *array_pointer);
bool delete_matrix_from_SD(unsigned int record);
