You initialize the serial communication via USB with
Serial.begin(baudrate);
where baudrate is a long specifying the number of symbols you want to send over the connection per second. You can put pretty much any number in there, but not every number makes sense.
One thing that I found odd though is that I can't seem to actually use a different baudrate than 9600. The sketch compiles and uploads just fine, but if I check the actual speed of the serial port via
setserial -ag port
where port is the port of my Teensy 4.0 board (that command is something you can use in the terminal of Linux) or with
Serial.baud();
directly in the sketch it always says 9600. I suspect that this is caused by something inside the code behind Serial.begin() since I can manually set the baudrate via the terminal in Linux using
stty speed baudrate < port > port
where (again) baudrate is the speed I want to use and port is the port of my board (checking it with the first terminal command: it works). But when restarting the program on the board the baudrate reverts to 9600.
Does anyone know why this is and how to fix this?
LukasFun
  • 295
The whole concept of Baud Rate with USB communication is completely meaningless. There is no such thing as "baud rate" over USB.
What there is, and what you are confusing with "baud rate" is a configuration item which the host can send to the device which is a "I would like you to communicate with other devices at this speed" configuration item.
This is intended for use with USB to UART adaptors where it is used to configure the baud rate of a physical UART interface for downstream communication.
When you set the baud rate in your code it is ignored, since it has no meaning.
When you set the baud rate on your computer it sends it as this configuration value, which you can then retrieve, should you have an interest in that value, using the Serial.baud() function.
Majenko
  • 105,851
  • 82
  • 139
The problem may be in flow control, as LukasFun suggested. Obviously, a low speed RS232 device will not be able to handle a continuous data stream at 1.5 Mbps
A quick look at this paper may help. https://www.usconverters.com/index.php?main_page=page&id=49&chapter=0
Rob
