I want to split a received binary data into two binary data.
Take the following received binary data for instance:
uint32_t data = 0xFFFF0001;
In binary format it is: 11111111111111110000000000000001
If we need to split this above binary into two new binary data how could it be done?
As an example from the 0xFFFF0001, how can we obtain the first 17-bit as as data1 = 11111111111111110 and then the remaining 15-bit as data2 = 000000000000001 ?
Michel Keijzers
  • 13,014
  • 41
  • 58
floppy380
  • 245
You can use the bit shift and and operator, like:
The following line will shift all bits 15 places to the right, meaning the least significant 15 bits will be removed, and the other bits shifted to the right.
uint32_t dataLeft = data >> 15;
| Bit shift   || orig. bits    ||Removed bits |
For the other 15 bits, you can use the and operator, which just makes all 1's 0's for those bits not in the bit mask (0x7FFF).
uint16_t dataRight = data & 0x7FFF;
value:              11111111111111110000000000000001
bit mask (0x7FFF):  00000000000000000111111111111111
                    -------------------------------- & / AND
                    00000000000000000000000000000001
Michel Keijzers
  • 13,014
  • 41
  • 58
