evrything worked for a bit and changed to much to get it working again. dont really understand the error.
[![C:\Users\bavob\AppData\Local\Temp\ccyfrkaL.ltrans0.ltrans.o: In function `loop':
C:\Users\bavob\Documents\Arduino\counte_up/counte_up.ino:96: undefined reference to `num_Write(int)'
collect2.exe: error: ld returned 1 exit status
exit status 1 Fout bij het compileren voor board Arduino/Genuino Uno]1]1
  { 1, 1, 1, 1, 1, 0, 1 }, // 0
  { 0, 1, 1, 0, 0, 0, 0 }, // 1
  { 1, 1, 0, 1, 1, 1, 0 }, // 2
  { 1, 1, 1, 1, 0, 1, 0 }, // 3
  { 0, 1, 1, 0, 0, 1, 1 }, // 4
  { 1, 0, 1, 1, 0, 1, 1 }, // 5
  { 1, 0, 1, 1, 1, 1, 1 }, // 6
  { 1, 1, 1, 0, 0, 0, 0 }, // 7
  { 1, 1, 1, 1, 1, 1, 1 }, // 8
  { 1, 1, 1, 0, 0, 1, 1 }  // 9
int pin = 2;
int buttonState = 0;
const int button = 12;
int led = 13;
int randVal;
bool pressVal;
void num_Write(int);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(led, OUTPUT);
  Serial.begin(9600);
  pinMode(button, INPUT);
  buttonState = digitalRead(button);
  if (buttonState == LOW) {
    turnOff();
    pressVal = false;
  else
    if (pressVal == false)
      randVal = rand() % 10;
      pressVal = true;
    Serial.println(randVal);
    if (randVal == 0)
      void zero(int number);
      num_Write(0);
    else if (randVal == 1)
      void one(int number);
      num_Write(1);
    else if (randVal == 2)
      void two(int number);
      num_Write(2);
    else if (randVal == 3)
      void three(int number);
      num_Write(3);
    else if (randVal == 4)
      void four(int number);
      num_Write(4);
    else if (randVal == 5)
      void five(int number);
      num_Write(5);
    else if (randVal == 6)
      void six(int number);
      num_Write(6);
    else if (randVal == 7)
      void seven(int number);
      num_Write(7);
    else if (randVal == 8)
      void eight(int number);
      num_Write(8);
    else
      void nine(int number);
      num_Write(9);
  for (int j = 0; j < 7; j++) {
    digitalWrite(pin, num_array[number][j]);
    pin++;
    pin++;
    pin++;
    pin++;
    pin++;
    pin++;
    pin++;
    pin++;
    pin++;
    pin++;
void turnOff()
Michel Keijzers
  • 13,014
  • 41
  • 58
Bavo
You call function num_Write a lot, you create a forward declaration:
But you forgot to create the implementation.
If you would have forgot the forward declaration the function would not be known at all (and you would get a compiler error). But with the forward declaration you let the compiler know the signature of num_write (so the return value and argument types).
When the linker wants to link all object (.o) files together it cannot find an implementation of the function num_write and you get this error. Hence ld is the linker.
Michel Keijzers
  • 13,014
  • 41
  • 58
