I have been using the Arduino to record some data. In my Arduino sketch I also used the millis() function so I can keep track of the time at which each value I am measuring is taken. However, I noticed that the timing isn't correct. For example 30 seconds in real life only comes out as 10 seconds (made up example).
Am I correct in saying that the Arduino delay function affects the time keeping using millis()? In other words suppose I have a delay of 50ms, does that mean the millis() function stops for that duration as well and then continues and so on for the duration of the connection? I noticed this when I tried plotting some data and finding that the frequency of the peaks in my data was too frequent given the time which had passed by. So I want to know if that is the reasoning for this mismatch of timing and if so, how do I fix this so that I can keep the time each sample occurs?
To give some context here is my sketch:
#include <eHealth.h>
unsigned long time;
// The setup routine runs once when you press reset:
Serial.begin(9600);
// The loop routine runs over and over again forever:
float ECG = eHealth.getECG();
time = millis();
Serial.print(time);
Serial.print(" ");
Serial.print(ECG, 5);
Serial.println("");
delay(50);
