I am just trying to use an ultrasonic sensor with a buzzer but the buzzer doesn't respond to my code. I mean it doesn't make any sound. I tested it to check if by sending 5 volts to it, it will make a sound.. and it did... but using this code below... for some reason, it doesn't make any sound....
#include <NewPing.h>
#define TRIGGER_PIN 11
#define  ECHO_PIN 12
#define buzzer 13
NewPing sonar1 (TRIGGER_PIN, ECHO_PIN);
long inches1;
int sound = 250;
void setup (){
  Serial.begin (9600);
  pinMode (TRIGGER_PIN, OUTPUT);
  pinMode (ECHO_PIN, INPUT);
  pinMode (buzzer, OUTPUT);
void loop () {
  inches1 = sonar1.ping_in();
   if (inches1 <= 5 ){
 //   sound = 250;
    tone(buzzer, 1000); // Send 1KHz sound signal...
    delay(1000);        // ...for 1 sec
    noTone(buzzer);     // Stop sound...
    delay(1000);
    Serial.print (inches1);
    Serial.print ('\n');
  delay (200);
Nouman
  • 217
If you have a look at the complete error message you will see that there is a collision between the libraries NewPing and Tone.
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Tone.cpp.o (symbol from plugin): In function `timer0_pin_port':
(.text+0x0): multiple definition of `__vector_7'
libraries\NewPing\NewPing.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
MatsK
  • 1,366
