Is it possible for arduino Due to act as DMA-SPI-slave device which can exchange SPI data (uint16_t TX[10] and RX[10]) in triggered slave mode?
I have a setup in which time period is very short (~500uS/cycle). so I need to exchange data with another Microcontroller (acting as 'Master') within the mensioned time limit. Some other tasks are also to be processed. This is why I have to go for DMA and fast data transfer without intervension of processor. All the codes available are to be used in Master mode of SPI. Not a single one is in SLAVE mode. I wrote a code but I cannot implement a transfer triggered by SPI hardware. Also how to implement data transfer complete Interrupt after all 10 datas(16bit) have been transferred and received? Here is my initialization code:
    void DMAslaveBegin()
    // Configure the pins for SPI in peripheral mode
    PIO_Configure(
        g_APinDescription[PIN_SPI_MOSI].pPort,
        g_APinDescription[PIN_SPI_MOSI].ulPinType,
        g_APinDescription[PIN_SPI_MOSI].ulPin,
        g_APinDescription[PIN_SPI_MOSI].ulPinConfiguration);
    PIO_Configure(
        g_APinDescription[PIN_SPI_MISO].pPort,
        g_APinDescription[PIN_SPI_MISO].ulPinType,
        g_APinDescription[PIN_SPI_MISO].ulPin,
        g_APinDescription[PIN_SPI_MISO].ulPinConfiguration);
    PIO_Configure(
        g_APinDescription[PIN_SPI_SCK].pPort,
        g_APinDescription[PIN_SPI_SCK].ulPinType,
        g_APinDescription[PIN_SPI_SCK].ulPin,
        g_APinDescription[PIN_SPI_SCK].ulPinConfiguration);
    PIO_Configure(
        g_APinDescription[PIN_SPI_SS0].pPort,
        g_APinDescription[PIN_SPI_SS0].ulPinType,
        g_APinDescription[PIN_SPI_SS0].ulPin,
        g_APinDescription[PIN_SPI_SS0].ulPinConfiguration);
    //pmc_enable_periph_clk(ID_SPI0);
#if USE_SAM3X_DMAC
    pmc_enable_periph_clk(ID_DMAC);
    DMAC_Disable();
    DMAC->DMAC_GCFG = DMAC_GCFG_ARB_CFG_FIXED;  //Fixed priority arbiter
    DMAC_Enable();
#if USE_SAM3X_BUS_MATRIX_FIX    // not active here
    MATRIX->MATRIX_WPMR = 0x4d415400;
    MATRIX->MATRIX_MCFG[1] = 1;         //Single Access
    MATRIX->MATRIX_MCFG[2] = 1;         //Single Access
    MATRIX->MATRIX_SCFG[0] = 0x01000010;
    MATRIX->MATRIX_SCFG[1] = 0x01000010;
    MATRIX->MATRIX_SCFG[7] = 0x01000010;
#endif  // USE_SAM3X_BUS_MATRIX_FIX
#endif  // USE_SAM3X_DMAC
    //  initialize SPI controller - Slave mode
    SPI.begin(_pin);
    SPI_Disable(SPI0);
    REG_SPI0_CR = SPI_CR_SWRST;     // reset SPI
    REG_SPI0_CR = SPI_CR_SPIEN;     // enable SPI
    REG_SPI0_MR = 0x10;              // DLYBCS=0, PCS=0, MODFDIS=1, PS=0, MSTR=0(slave)
    REG_SPI0_CSR = 0x80;            // DLYBCT=0, DLYBS=0, SCBR=0, 16 bit transfer, Mode 0/1
    REG_SPI0_IDR = ~SPI_IDR_RDRF;
    REG_SPI0_IER = SPI_IDR_RDRF;
    NVIC_EnableIRQ(SPI0_IRQn);
    SPI_Enable(SPI0);
Is this a valid condition for DMA? How can I utilize SPI ISR handler like system in DMA for my code so that the complete transaction (simultaneous Transmit & Receive) becomes fully automatic without processor utilization?
