I know that I can program Arduino with python but is it possible to make every project, which can be completed by normal IDE?
dda
  • 1,595
Tanishq Jaiswal
  • 181
I imagine you want to use python because you are already familiar with it, know your way around the syntax, etc. But I would advice against this line of thinking, because microcontrollers need a little more of "low-level" thinking (given the limited resources they generally have) and because of that, it's probably best if you learn some C/C++.
The arduino programming framework provides some not-so-low-level libraries and tools (like the arduino IDE itself) to make it easy for non-C programmers to learn C-like programming.
However, if you want to use python as a proof of concept or anything else, sorry about the misunderstanding! :)
jotadepicas
  • 326
The direct answer is almost certainly not.
There are some auspicious developments so that you might be able to adapt a specific open source Python package, but the resulting software would require a special Arduino board with an MCU chip with much more SRAM and a higher clock speed than we usually see on Arduino boards.
Discussion
I have looked several times and have never found anything.
I did find a "stripped down" implementation of a Python 3.3 interpreter called Micro Python. The software was developed hand in hand with MicroPy, an ARM-based single board computer (also described at the MicroPython website). MicroPy is closer to a Raspberry Pi or Beaglebone than an Arduino. However, the software environment is less complex because the MicroPy doesn't require a Linux-based or other operating system.
The base Micro Python package software package seems to require about 110KB of SRAM to boot up and expects a 1 MB SD chip with a boot record and MicroPython on it.
The Micro Python software was released under the MIT open source license so, in theory, a clever person could adapt it for the Arduino if they built a board with a really powerful chip SD socket.
Although the Micro Python/MicroPy package is very appealing, I don't think I would head down the path. I would rather be programming for hardware that is available from more than one source.
Another potential issue is that the Micro Python implementation uses a mark and sweep garbage collector which might tie up the processor for 4 msec at time. Depending on your application a 4 msec busy period might not be acceptable.
WesR
  • 111
Not really, since python is an interpreted programming language. If you are not new to the microcontrollers' world and have same experience, maybe this Board is you what you want. More powerful than Arduino and completely programble using Python 3.
Topic: Can I use Python to program Arduino?
Dave
  • 349
