I am doing a data logger with an Arduino Mega2560 and I want to use a code to make it sleep when no measure is needed and wake it up with an RTC when time comes. The reason I want this is because I intend to run the code on a Pro Mini later so I need to save as much energy as I can. I am able to put the arduino to sleep using the alarm interrupt when a minute is passed but it doesn't wake up from sleep afterwards.
Here is the code I am using:
#include <Wire.h>
#include <RtcDS3231.h>
#include <avr/sleep.h>
const byte interruptPin = 2;
volatile bool alarm = 0;
volatile byte counter = 0;
RtcDS3231<TwoWire> rtcObject(Wire);
Serial.begin(9600);
Serial.println("Initialisation");
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), handleInterrupt, FALLING);
rtcObject.Begin();
RtcDateTime timestamp = RtcDateTime(__DATE__, __TIME__);
rtcObject.SetDateTime(timestamp);
rtcObject.Enable32kHzPin(false);
rtcObject.SetSquareWavePin(DS3231SquareWavePin_ModeAlarmOne);
DS3231AlarmTwo alarm2(
0,
0,
0,
DS3231AlarmTwoControl_OncePerMinute);
rtcObject.SetAlarmTwo(alarm2);
rtcObject.LatchAlarmsTriggeredFlags();
if (alarm == true){
handleAlarm();
if (counter == 1){
mesure();
counter = 0;
delay(100);
sleepNow();
void handleInterrupt() {
alarm = true;
counter ++;
Serial.println(counter);
void handleAlarm() {
alarm = false;
void mesure(){
RtcDateTime timestamp = rtcObject.GetDateTime();
Serial.print("time interrupt at: ");
char time[10];
sprintf(time, "%d:%d:%d",
timestamp.Hour(),
timestamp.Minute(),
timestamp.Second()
Serial.println(time);
void sleepNow() {
Serial.println("Entering sleeping");
delay(100);
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
sleep_enable(); // enables the sleep bit in the mcucr register
attachInterrupt(digitalPinToInterrupt(interruptPin),wakeUpNow, FALLING); // use interrupt 0 (pin 2) and run function
sleep_mode(); // here the device is actually put to sleep!!
// THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
sleep_disable(); // first thing after waking from sleep: disable sleep...
detachInterrupt(digitalPinToInterrupt(interruptPin)); // disables interrupt 0 on pin 2 so the wakeUpNow code will not be executed during normal running time.
void wakeUpNow() {
// execute code here after wake-up before returning to the loop() function
// timers and code using timers (serial.print and more...) will not work here.
// we don't really need to execute any special functions here, since we
// just want the thing to wake up
Serial.println("Woke up");
delay(100);
I want to understand how to wake it up properly so I can later make it sleep first in the loop and wake it up only if an interrupt is detected from the rtc.
Thank you for your help !
