I am programming Arduino UNO for this functionality: with use of SD card reader module and SIM900 GSM/GPRS shield I am trying to: 1. Pick up incomming call, play message from SD file and after the message ends, hang up. 2. Call from Arduino to defined telephone number, after the call is picked up, play message and after the message ends, hang up. 3. In case of outcomming call (arduino calls to defined number) and its declined or not picked up, Arduino makes another try for a total of 3 tries. 4. I want to play the message in Czech language OR English message, based on pushed/unpushed button.
Its all working, but number 4. the button for language switch is not working. If I place in code another "digitalRead(pin)" Arduino does all the stuff but does not play the message - its silent on the other end. If I delete this line of code, it is working. So the functionality is good, but the language switch is not working. I have tried to switch it to Global/Local variables, tried to put it straight into the If statement. Everything is wrong.
Any ideas? Thank you.
Code:
#include <GPRS_Shield_Arduino.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <SD.h>
#include <TMRpcm.h>
#include "SPI.h"
#define SD_ChipSelectPin 10
#define PIN_TX 7
#define PIN_RX 8
#define BAUDRATE 9600
#define MESSAGE_LENGTH 20
GPRS gprs(PIN_TX, PIN_RX, BAUDRATE);
TMRpcm tmrpcm;
char telefon[] = "999999999";
//char *s = NULL;
char englishMessage[] = "Hlas6en.wav";
char czechMessage[] = "Hlas6cz.wav";//"Hlas6cz.wav";
char gprsBuffer[64];
//char in_number[16] = {0};
unsigned long englishMessageTime = 11000;
unsigned long czechMessageTime = 11000;
int callRetry = 2; //pocet pokusu opakovaneho telefonatu
//int i = 1;
//int inComing = 0;
bool callPrev = false;
bool callAct = false;
bool call = false;
uint8_t PIN_RST = 2;
int PIN_INPUT = 4;
//int LANGUAGE_INPUT = 6;
bool languageSwitch = HIGH;
void setup()
pinMode(PIN_INPUT, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
Serial.begin(BAUDRATE);
//delay(10000); //NECHAT!
while (!gprs.init())
Serial.println("SIM 900 - INIT ERROR");
gprs.powerReset(PIN_RST);
delay(7000);
while (!SD.begin(SD_ChipSelectPin))//SD_ChipSelectPin
Serial.println("SD fail");
delay(1000);
//return;
Serial.println("Zapnuto.");
tmrpcm.speakerPin = 9;
tmrpcm.setVolume(5);
//sim900_clean_buffer(gprsBuffer, 32);
//gprs.callUp(telefon);
//languageSwitch = digitalRead(3);
if ((gprs.readable()) || call)
sim900_read_buffer(gprsBuffer, 32, DEFAULT_TIMEOUT);
Serial.print(gprsBuffer);
if (NULL != strstr(gprsBuffer, "OK"))
Serial.println("Hovor prijat.");
playAudio();
Serial.println("Zprava prehrana, pokladam.");
gprs.hangup();
callRetry = 2;
else if (NULL != strstr(gprsBuffer, "RING"))
Serial.println("Prijimam prichozi hovor.");
gprs.answer(); //zvednuti telefonu v pripade prichoziho hovoru
callRetry = 2;
else if ((NULL != strstr(gprsBuffer, "BUSY")) || call)
if (callRetry == 0)
callRetry = 2;
Serial.println("Nedovolal jsem se.");
else if ((callRetry > 0) && (!call))
Serial.print("Zbyva pocet pokusu:");
Serial.println(callRetry - 1);
gprs.callUp(telefon); //Opakovane volani v pripade polozeni
callRetry--;
else if ((callRetry == 2) && (call))
Serial.println("Volam");
call = false;
//smazani bufferu
callPrev = callAct;
callAct = !digitalRead(PIN_INPUT);
call = !callPrev && callAct;
//languageSwitch=digitalRead(LANGUAGE_INPUT);
delay(1000);
Serial.println(call);
//Serial.println(languageSwitch);
void playAudio()
bool languageSwitch = digitalRead(3); //PROBLEM!!!
if (!SD.begin(SD_ChipSelectPin))//SD_ChipSelectPin
return;
Serial.println("Prehravani zpravy.");
if (languageSwitch==HIGH)
Serial.println("Prehravam zpravu v cestine");
tmrpcm.play(czechMessage);//czechMessage
delay(czechMessageTime);
else
Serial.println("Prehravam zpravu v anglictine");
tmrpcm.play(englishMessage);//englishMessage
delay(englishMessageTime);
return;
