NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE);
AF_DCMotor motor1(1, MOTOR12_1KHZ);
AF_DCMotor motor2(2, MOTOR12_1KHZ);
AF_DCMotor motor3(3, MOTOR34_1KHZ);
AF_DCMotor motor4(4, MOTOR34_1KHZ);
Servo myservo;
boolean goesForward=false;
int distance = 100;
int speedSet = 0;
myservo.attach(10);
myservo.write(115);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
int distanceR = 0;
int distanceL = 0;
delay(40);
if(distance<=15)
moveStop();
delay(100);
moveBackward();
delay(300);
moveStop();
delay(200);
distanceR = lookRight();
delay(200);
distanceL = lookLeft();
delay(200);
if(distanceR>=distanceL)
turnRight();
moveStop();
}else
turnLeft();
moveStop();
}else
moveForward();
int lookRight()
myservo.write(50);
delay(500);
int distance = readPing();
delay(100);
myservo.write(115);
return distance;
int lookLeft()
myservo.write(170);
delay(500);
delay(100);
myservo.write(115);
return distance;
delay(100);
int readPing() {
delay(70);
int cm = sonar.ping_cm();
if(cm==0)
cm = 250;
return cm;
void moveStop() {
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void moveForward() {
if(!goesForward)
goesForward=true;
motor1.run(FORWARD);
motor2.run(FORWARD);
motor3.run(FORWARD);
motor4.run(FORWARD);
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
motor1.setSpeed(speedSet);
motor2.setSpeed(speedSet);
motor3.setSpeed(speedSet);
motor4.setSpeed(speedSet);
delay(5);
void moveBackward() {
goesForward=false;
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
delay(5);
void turnRight() {
delay(500);
void turnLeft() {
delay(500);
Asked
Active
Viewed 403 times
All of the errors I got were "NewPing does not name a type", "AF_DCMOtor does not name a type" and "motor<> was not declared in this scope". I don't see library includes; at least one for NewPing is needed. I don't know where AF_DCMotor is supposed to be declared but, as it is not declared as a type, it leaves all of the motor undefined. Those are the bulk (if not all) of the errors as the code stands now. Add the missing NewPing library do whatever you need to to define AF_DCMotor.
JRobert
- 15,407
- 3
- 24
- 51
It probably needs a library. Looks like you have some kind of AFDC library and did not use it.
