I'm trying controll the power of attity13a and turn off/turn on the led.
I'm going to goals:
  • After to click on the button0 led will blicking 5 second nad then the attiny13a going to sleep.
  • After to click on the button1 then wake attiny13a up and then led will shane.
The button0 to sleep and blink the led. the button1 to wake up and turn on the led.
Could you explain what is wrong in this sketch, please? thank you for your answers.
code:
    #define F_CPU   1200000UL
    #define LED     PB2 // PB2
    #define BUTTON1 PB1 // PCINT1
    #define BUTTON0 PB0 // PCINT0
    #define HIGH         1
    #define LOW          0
    #define INPUT        0
    #define OUTPUT       1
    #define INPUT_PULLUP 2
    #define FALSE        0
    #define TRUE         1
    #define _BV(bit)    (1 << (bit))
    #include <avr/io.h>
    #include <avr/interrupt.h>
    #include <avr/sleep.h>
    #include <util/delay.h>
    void pinMode(uint8_t pin, uint8_t mode)
        if(mode == OUTPUT) // Pin as output
            DDRB |= _BV(pin);
        else // Pin as input or input pullup
            DDRB &= ~_BV(pin); // Set pin as input
            if(mode == INPUT_PULLUP)
                PORTB |= _BV(pin); // Enable pullup resistors
    void digitalWrite(uint8_t pin, uint8_t val)
      if(val)
        PORTB |= _BV(pin);  // Set pin high
      else
        PORTB &= ~_BV(pin); // Set pin low
    uint8_t digitalRead(uint8_t pin)
      return !!(PINB & _BV(pin));
    // go to sleep
    ISR(PCINT0_vect)
       if(digitalRead(BUTTON0)){
            int i=0;
            while(i<10){
                blink();i=i+1;
            set_sleep_mode(SLEEP_MODE_PWR_DOWN);
            sleep_enable();
            sleep_cpu();
    //wake up
    ISR(PCINT1_vect){
       if(digitalRead(BUTTON1)){
        digitalWrite(LED, HIGH);
    void blink(){
        digitalWrite(LED, LOW);
        _delay_ms(500);
        _delay_ms(500);
    int main(void)
        pinMode(BUTTON0, INPUT_PULLUP);
        pinMode(BUTTON1, INPUT_PULLUP);
        pinMode(LED, OUTPUT);
        // Sets the Pin change interrupt mask PB0, PB1
        PCMSK |= _BV(PCINT0)|_BV(PCINT1);
        //Enables Interrupts globally after setup
        //sei();
        SREG |= _BV(SREG_I);
        while(TRUE){}
Kvartu
  • 33
#define BUTTON1 PB1 // INT0
#define HIGH         1
#define LOW          0
#define INPUT        0
#define OUTPUT       1
#define FALSE        0
#define TRUE         1
#include <avr/io.h>
void pinMode(uint8_t pin, uint8_t mode){
        DDRB |= _BV(pin);
void digitalWrite(uint8_t pin, uint8_t val){
  if(val)
  else
uint8_t digitalRead(uint8_t pin){
//wake up
ISR(INT0_vect){
   sleep_disable();
   //cli(); // Turn off global interrupts
void blink(){
    _delay_ms(1000);
    _delay_ms(1000);
// go to sleep
ISR(PCINT0_vect)
   if(!digitalRead(BUTTON0)){
        blink();
        sei(); // Turn on global interrupts
        sleep_enable();
        sleep_cpu();
int main(void)
    //enabled external interrupt
    MCUCR=0;
    //MCUCR=0b00000000;
    GIMSK|=_BV(INT0); // enabled external interrupt INT0 - PB1
    GIMSK|=_BV(PCIE);
    PCMSK|=_BV(PCINT0);//PB0
    pinMode(BUTTON1, INPUT_PULLUP);//INT0 - PB1
    pinMode(BUTTON0, INPUT_PULLUP);//PCINT0 - PB0
    //SREG |= _BV(SREG_I);
    sleep_enable();
    sleep_cpu();
    while(TRUE){}
    return 0;
Kvartu
  • 33
