I am trying to send the data from DHT sensor (temperature and humidity on 2 channels of Thingspeak cloud server) and firstly display them on Thingspeak cloud. Afterwards I will need to get those data from the cloud and use them with Python in order to make some calculations. Sensor data is sent via SIM900 GSM module.
I succeeded to send some constant value to Thingspeak by executing AT commands, one by one, which I put later in this code: https://pastebin.com/4bP6hgk7 EDIT: Here is the code:
#include <SoftwareSerial.h>
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT11
// Initialize DHT sensor for normal 16mhz Arduino
DHT dht(DHTPIN, DHTTYPE);
// Create global varibales to store temperature and humidity
float t; // temperature in celcius
float f; // temperature in fahrenheit
float h; // humidity
SoftwareSerial gsm(7, 8);
dht.begin();
gsm.begin(9600);
Serial.begin(9600);
gsm.println("AT+IPR=9600");
delay(1000);
gsm.println("AT+CGATT=1");
delay(1000);
gsm.println("AT+SAPBR=1,1");
delay(1000);
ShowSerialData();
gsm.println("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"");
delay(1000);
ShowSerialData();
gsm.println("AT+SAPBR=3,1,\"APN\",\"prepaidnet\"");
delay(1000);
ShowSerialData();
gsm.println("AT+SAPBR=3,1,\"USER\",\"mts\"");
delay(1000);
ShowSerialData();
gsm.println("AT+SAPBR=3,1,\"PWD\",\"064\"");
delay(1000);
ShowSerialData();
delay(1000);
ShowSerialData();
gsm.println("AT+SAPBR=2,1");
delay(1000);
ShowSerialData();
gsm.println("AT+HTTPTERM");
delay(1000);
ShowSerialData();
gsm.println("AT+HTTPINIT");
delay(2000);
ShowSerialData();
gsm.println("AT+HTTPPARA=\"CID\",1");
delay(3000);
ShowSerialData();
// put your main code here, to run repeatedly:
while(gsm.available()) {
Serial.write(gsm.read());
if(Serial.available()) {
gsm.write(Serial.read());
t=readTemp();
h=readHum();
gsm.print("AT+HTTPPARA=\"URL\",\"https://api.thingspeak.com/update?api_key=Z1Q5633A4S1GHIHU&field1=26");
//gsm.print(t);
//gsm.println();
delay(5000);
//gsm.println((char)26);
ShowSerialData();
delay(1000);
gsm.println("AT+HTTPPARA=\"REDIR\",1");
delay(3000);
gsm.println("AT+HTTPSSL=1");
delay(3000);
gsm.println("AT+HTTPACTION=0"); /* Start POST session */
delay(5000);
gsm.println("AT+HTTPREAD");
delay(3000);
gsm.println("AT+HTTPTERM"); /* Terminate HTTP service */
delay(5000);
gsm.println("AT+SAPBR=0,1");
delay(3000);
ShowSerialData();
float readTemp() {
// Read temperature as Celsius
t = dht.readTemperature();
//Read humidity
h = dht.readHumidity();
// Compute temperature values in Celcius
t = dht.computeHeatIndex(t,h,false);
// Check if any reads failed and exit early (to try again).
if (isnan(t)) {
Serial.println("Failed to read temp from DHT sensor!");
return 1;
return t;
float readHum() {
//Read humidity
if (isnan(h)) {
Serial.println("Failed to read hum from DHT sensor!");
return 1;
return h;
void ShowSerialData()
while(gsm.available()!=0)
The problem is that not the whole script is executed - AT+HTTPPARA command with the parameter "URL" and the URL where the data should be sent is not being executed. I have read many answers but could't find the answer for this. Could anybody help with this issue? Thanks in advance!
