According the prototype of f and the usage pattern for its x
argument, the function expects this argument to be a pointer to the
first element of an array of pointers to the first elements of arrays of
int. However, the matrix in main() is defined as an array of arrays
of int. If you try to pass this to a function, the matrix will decay
into a pointer to an array of int. That's not what you want.
If you want both dimensions of the matrix to be variable, the only
simple solution I see is to build an extra array of pointers (pointing
to the matrix rows) and pass that array to the function
int main() {
int x[16][128];
// Build an array of pointers to rows.
int *px[16];
for (int i = 0; i < 16; i++)
px[i] = x[i];
f(px, 16, 128);
For more information on this, see the section Arrays and Pointers in
the C FAQ, and more specifically the questions 6.16 (How can I
dynamically allocate a multidimensional array?) and 6.19 (How do I write
functions which accept two-dimensional arrays when the width is not
known at compile time?).
