I have a single function for debugging messages, used through all the project. When KEYDEBUG is defined as 1 or 0, the function is enabled or disabled as required.
#define KEYDEBUG 0
void debugging(int var){
   #if KEYDEBUG
   //Assert
   #endif
When checking the compiler, the variable var raises a warning -Wunused-parameter. How should remove this warning just at this part of the project? Or which other alternative for using debugging code and removing it from memory for production release?
VE7JRO
  • 2,515
  • 29
Brethlosze
  • 337
In your case you do not use the entire body, so you can use a macro.
This way the code when KEYDEBUG is 0, will be like the complete function would not exist (except for the void cast, see below).
#include "assert.h"
#define KEYDEBUG 0
#ifndef KEYDEBUG
#define debugging(x) void(x);
#endif
   assert(var);
  debugging(1);
The information below is for not using the function parameter, but keep the function (in case you have code in your function that also does something when KEYDEBUG is 0.
Unused attribute
The cleanest way I could find is using the unused attribute:
#if KEYDEBUG
   void debugging(__attribute__((unused)) int var){
      //Assert
#else
      //Assert
#endif
or if you prefer better readability:
#if KEYDEBUG
      //Assert
#else
      //Assert
#endif
Cast to void
Less clean but does the job:
   #if KEYDEBUG
      //Assert
   #else
      (void) var; // prevent unused parameter warning
   #endif
Macros/Parameter
It's not easy to remove the variable since it's used in a function and will be called from many places probably. You could maybe you use a macro but that gets messy soon.
This solution works, and afaik the compiler will optimize the code out (if not , it will cost very less anyway).
Michel Keijzers
  • 13,014
  • 41
  • 58
