My code below reads data from an ADC and 3 digital pins via a Mega and prints to an SD Shield (Deek Robot). I want to be able to read the data every 50ms (20ms ideally). I can't get below 250ms.
I've read countless forum posts regarding the same issue and understand that I need to create 2x 512 byte buffer, store data to one while the other is being written to the SD card. A forum post mentioned using the Adafruit GPS library for an example of double-buffering but I can't seem to find it. Another suggests changing the internal buffer from 64bytes to 256bytes in hardwareserial.cpp but I can't even navigate to it on my w***ows laptop.
I've run dataString.Length and the max length is 38 for the 8 columns of data, plus a long (for recording ms) another byte for the "\t" and 3 bytes of headroom = 46bytes in all, round it up to 50bytes/sample at a 50ms sampling rate is 1000bytes/second. Darn it, I forgot to add the separating-commas between the columns = plus another 7 bytes; call it 55 in total = 1100bytes/second. I know it can be done but I can't do it; not at my current knowledge/skill level.
Thank you in advance for your help.
//include relevant libraries
#include <EnableInterrupt.h>
#include <SPI.h>
#include <SD.h>
//globally define pins
#define BUSY 3 //purple*
#define RD 4 //yellow* RD+CS tied together
#define RESET 5 //grey*
#define CONVST 6 //green* CONVSTA+CONVSTB soldered together on the board
#define RANGE 7 //blue* *not permanent - double check!!!*
#define DB0 22
#define DB1 23
#define DB2 24
#define DB3 25
#define DB4 26
#define DB5 27
#define DB6 28
#define DB7 29
#define DB8 30
#define DB9 31
#define DB10 32
#define DB11 33
#define DB12 34
#define DB13 35
#define DB14 36
#define DB15 37
//byte statusLed = 13;
byte sensorPin1 = 38;
byte sensorPin2 = 40;
byte sensorPin3 = 42;
int sensorValue[8];
int rawData[16];
//change the size of these arrays to match the amount of channels being read by the ADC
int adcChannel[5];
int adcData[5];
int channelCount=5;
volatile byte pulseCount1;
volatile byte pulseCount2;
volatile byte pulseCount3;
int pulses[3];
// cs pin for sd-shield *NB 53 for Mega
const int chipSelect = 53;
// SCK 52
// MISO 50
// MOSI 11
unsigned long oldTime;
void setup() { //set up the hardware
Serial.begin(9600);
//sd card.....
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
enableInterrupt(BUSY, bitBang, FALLING);
oldTime = 0;
pinMode(DB0, INPUT_PULLUP);
pinMode(DB1, INPUT_PULLUP);
pinMode(DB2, INPUT_PULLUP);
pinMode(DB3, INPUT_PULLUP);
pinMode(DB4, INPUT_PULLUP);
pinMode(DB5, INPUT_PULLUP);
pinMode(DB6, INPUT_PULLUP);
pinMode(DB7, INPUT_PULLUP);
pinMode(DB8, INPUT_PULLUP);
pinMode(DB9, INPUT_PULLUP);
pinMode(DB10, INPUT_PULLUP);
pinMode(DB11, INPUT_PULLUP);
pinMode(DB12, INPUT_PULLUP);
pinMode(DB13, INPUT_PULLUP);
pinMode(DB14, INPUT_PULLUP);
pinMode(DB15, INPUT_PULLUP);
pinMode(RESET, OUTPUT);
pinMode(CONVST, OUTPUT);
pinMode(RD, OUTPUT);
pinMode(RANGE, OUTPUT);
pinMode(BUSY, INPUT);
//reset ADC to begin conversion
digitalWrite(RESET, HIGH);
delayMicroseconds(10);
digitalWrite(RESET, LOW);
digitalWrite(CONVST, LOW);
digitalWrite(RD, HIGH);
digitalWrite(RANGE, LOW);
digitalWrite(BUSY, LOW);
delayMicroseconds(100);
// Set up the status LED line as an output
// pinMode(statusLed, OUTPUT);
// digitalWrite(statusLed, HIGH); // We have an active-low LED attached
pinMode(sensorPin1, INPUT);
digitalWrite(sensorPin1, HIGH);
pinMode(sensorPin2, INPUT_PULLUP);
digitalWrite(sensorPin2, HIGH);
pinMode(sensorPin3, INPUT_PULLUP);
digitalWrite(sensorPin3, HIGH);
pulseCount1 = 0;
pulseCount2 = 0;
pulseCount3 = 0;
oldTime = 0;
// the hall effect sensors are configured to trigger on a FALLING state change
// (transition from HIGH state to LOW state)
enableInterrupt(sensorPin1, pulseCounter1, FALLING);
enableInterrupt(sensorPin2, pulseCounter2, FALLING);
enableInterrupt(sensorPin3, pulseCounter3, FALLING);
//change this value to preffered sampling rate
if ((millis() - oldTime) == 50) {
oldTime = millis();
//Serial.print(millis());
//Serial.print("\t");
//tell ADC to start read (converting analogue input to digital output)
digitalWrite(CONVST, HIGH);
//when read-conversion is complete ADC sends the BUSY pin low triggering the bitBang ISR
//print ADC data from array within the bitBang ISR to a string
String adcString = "";
for(int thisChannel=0; thisChannel<channelCount; thisChannel++){
adcString += String(adcData[thisChannel]);
adcString += ",";
//disable interrupt to access current pulse count
disableInterrupt(sensorPin1);
disableInterrupt(sensorPin2);
disableInterrupt(sensorPin3);
//grab current pulse count and store in a variable
pulses[0] = pulseCount1;
pulses[1] = pulseCount2;
pulses[2] = pulseCount3;
//reset pulse count
pulseCount1 = 0;
pulseCount2 = 0;
pulseCount3 = 0;
//enable interrupt and start incrementing pulse count again
String pulseString = "";
for(int i=0; i<3; i++){
pulseString += String(pulses[i]);
if (i<2) {
pulseString += ",";
String dataString = String(adcString + pulseString);
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("dataLog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.print(millis());
dataFile.print(",");
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
//Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening dataLog.txt");
//start again
//grabbing ADC data ISR (for n channel)
void bitBang () {
//a for loop to bitbang the values fom the analogue (ADC) channels (maximum 8) sequentially storing them in a variable array (equal to the channels of the ADC)
//send ADC read pin low to bitbang the first channel
digitalWrite(RD, LOW);
//read the state of the 16 pins and store in a variable
rawData[0] = digitalRead(DB15);
rawData[1] = digitalRead(DB14);
rawData[2] = digitalRead(DB13);
rawData[3] = digitalRead(DB12);
rawData[4] = digitalRead(DB11);
rawData[5] = digitalRead(DB10);
rawData[6] = digitalRead(DB9);
rawData[7] = digitalRead(DB8);
rawData[8] = digitalRead(DB7);
rawData[9] = digitalRead(DB6);
rawData[10] = digitalRead(DB5);
rawData[11] = digitalRead(DB4);
rawData[12] = digitalRead(DB3);
rawData[13] = digitalRead(DB2);
rawData[14] = digitalRead(DB1);
rawData[15] = digitalRead(DB0);
//convert into 16bit 2s compliment and store in a variable array
adcData[thisChannel] = rawData[0] | (rawData[1] << 1) | (rawData[2] << 2) | (rawData[3] << 3) | (rawData[4] << 4) | (rawData[5] << 5) | (rawData[6] << 6) | (rawData[7] << 7) | (rawData[8] << 8) | (rawData[9] << 9) | (rawData[10] << 10) | (rawData[11] << 11) | (rawData[12] << 12) | (rawData[13] << 13) | (rawData[14] << 14) | (rawData[15] << 15);
//send ADC pin high to say we have read the first channel
//repeat for n channels
//counting pulses ISRs
void pulseCounter1(){
// Increment the pulse counter
pulseCount1++;
void pulseCounter2(){
pulseCount2++;
void pulseCounter3(){
pulseCount3++;
