I am trying to modularize the different components in my arduino build by using objects, but am having trouble with the one controlling a wireless transceiver, which uses SoftwareSerial.h
I believe I am (generally) setting up the use of these objects correctly because I have other objects that build correctly in other files.
I think my issue is somehow part of SoftwareSerial.h, but I am not knowledgeable enough to get in and diagnose it... I think my core issue is that SoftwareSerial is not being brought in properly.
Transciever.cpp
This code controls the HC-12 transciever
#include <Arduino.h>
#include <SoftwareSerial.h>
enum class TransReadStatus {
RELAY_OFF,
RELAY_ON,
NO_DATA
class TranscieverHandler {
public:
TranscieverHandler(
int txPinIn,
int rxPinIn,
int setPinIn,
int baudRateIn
): txPin(txPinIn),
rxPin(rxPinIn),
setPin(setPinIn),
baudRate(baudRateIn)
SoftwareSerial hc12(txPin, rxPin);
void init() {
hc12.begin(baudRate);
pinMode(setPin, OUTPUT);
digitalWrite(setPin, HIGH); // HC-12 normal, transparent mode
TransReadStatus checkForSignal() {
while (hc12.available()) { // If HC-12 has data
incomingByte = hc12.read(); // Store each icoming byte from HC-12
readBuffer += char(incomingByte); // Add each byte to ReadBuffer string variable
delay(100);
if (onBytes.equals(readBuffer)) {
readBuffer = "";
return TransReadStatus::RELAY_ON;
} else if (offBytes.equals(readBuffer)) {
readBuffer = "";
return TransReadStatus::RELAY_OFF;
readBuffer = "";
return TransReadStatus::NO_DATA;
TransReadStatus getLastRecievedStatus() {
TransReadStatus newStatus = checkForSignal();
if (newStatus == TransReadStatus::NO_DATA) {
return lastStatus;
lastStatus = newStatus;
return lastStatus;
protected:
const int txPin;// = 10;
const int rxPin;// = 11;
const int setPin;// = 12;
const int baudRate;// 9600
Constants for signals
const String setOnBytes = String("SET RELAY ON");
const String setOffBytes = String("SET RELAY OFF");
const String onBytes = String("STATUS: RELAY IS ON");
const String offBytes = String("STATUS: RELAY IS OFF");
SoftwareSerial hc12;
byte incomingByte;
String readBuffer = "";
TransReadStatus lastStatus = TransReadStatus::NO_DATA;
unsigned long lastSendOnSignal = millis();
Output from failed compilation:
Arduino: 1.8.9 (Linux), Board: "Arduino/Genuino Uno"
/home/greg/other/arduino-1.8.9/arduino-builder -dump-prefs -logger=machine -hardware /home/greg/other/arduino-1.8.9/hardware -tools /home/greg/other/arduino-1.8.9/tools-builder -tools /home/greg/other/arduino-1.8.9/hardware/tools/avr -built-in-libraries /home/greg/other/arduino-1.8.9/libraries -libraries /home/greg/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10809 -build-path /tmp/arduino_build_227628 -warnings=default -build-cache /tmp/arduino_cache_459309 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -verbose /home/greg/GitRepos/WirelessSwitch/SwitchController/SwitchController.ino
/home/greg/other/arduino-1.8.9/arduino-builder -compile -logger=machine -hardware /home/greg/other/arduino-1.8.9/hardware -tools /home/greg/other/arduino-1.8.9/tools-builder -tools /home/greg/other/arduino-1.8.9/hardware/tools/avr -built-in-libraries /home/greg/other/arduino-1.8.9/libraries -libraries /home/greg/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10809 -build-path /tmp/arduino_build_227628 -warnings=default -build-cache /tmp/arduino_cache_459309 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/greg/other/arduino-1.8.9/hardware/tools/avr -verbose /home/greg/GitRepos/WirelessSwitch/SwitchController/SwitchController.ino
Using board 'uno' from platform in folder: /home/greg/other/arduino-1.8.9/hardware/arduino/avr
Using core 'arduino' from platform in folder: /home/greg/other/arduino-1.8.9/hardware/arduino/avr
Detecting libraries used...
/home/greg/other/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/variants/standard /tmp/arduino_build_227628/sketch/SwitchController.ino.cpp -o /dev/null
/home/greg/other/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/variants/standard -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src /tmp/arduino_build_227628/sketch/SwitchController.ino.cpp -o /dev/null
Using cached library dependencies for file: /tmp/arduino_build_227628/sketch/Buttons.cpp
Using cached library dependencies for file: /tmp/arduino_build_227628/sketch/LEDs.cpp
Using cached library dependencies for file: /tmp/arduino_build_227628/sketch/Switches.cpp
/home/greg/other/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/variants/standard -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src /tmp/arduino_build_227628/sketch/Transciever.cpp -o /dev/null
/home/greg/other/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/variants/standard -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src /home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src/SoftwareSerial.cpp -o /dev/null
Generating function prototypes...
/home/greg/other/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/variants/standard -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src /tmp/arduino_build_227628/sketch/SwitchController.ino.cpp -o /tmp/arduino_build_227628/preproc/ctags_target_for_gcc_minus_e.cpp
/home/greg/other/arduino-1.8.9/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_227628/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
Using previously compiled file: /tmp/arduino_build_227628/sketch/Buttons.cpp.o
Using previously compiled file: /tmp/arduino_build_227628/sketch/Switches.cpp.o
/home/greg/other/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/variants/standard -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src /tmp/arduino_build_227628/sketch/SwitchController.ino.cpp -o /tmp/arduino_build_227628/sketch/SwitchController.ino.cpp.o
/home/greg/other/arduino-1.8.9/hardware/tools/avr/bin/avr-g++ -c -g -Os -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10809 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/cores/arduino -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/variants/standard -I/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src /tmp/arduino_build_227628/sketch/Transciever.cpp -o /tmp/arduino_build_227628/sketch/Transciever.cpp.o
Using previously compiled file: /tmp/arduino_build_227628/sketch/LEDs.cpp.o
/tmp/arduino_build_227628/sketch/Transciever.cpp: In constructor 'TranscieverHandler::TranscieverHandler(int, int, int, int)':
Transciever.cpp:23:26: error: no matching function for call to 'SoftwareSerial::SoftwareSerial()'
In file included from /tmp/arduino_build_227628/sketch/Transciever.cpp:5:0:
/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src/SoftwareSerial.h:92:3: note: candidate: SoftwareSerial::SoftwareSerial(uint8_t, uint8_t, bool)
SoftwareSerial(uint8_t receivePin, uint8_t transmitPin, bool inverse_logic = false);
/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src/SoftwareSerial.h:92:3: note: candidate expects 3 arguments, 0 provided
/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src/SoftwareSerial.h:50:7: note: candidate: constexpr SoftwareSerial::SoftwareSerial(const SoftwareSerial&)
class SoftwareSerial : public Stream
/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src/SoftwareSerial.h:50:7: note: candidate expects 1 argument, 0 provided
/tmp/arduino_build_227628/sketch/Transciever.cpp: In member function 'void TranscieverHandler::init()':
/tmp/arduino_build_227628/sketch/Transciever.cpp:29:26: warning: passing 'const SoftwareSerial' as 'this' argument discards qualifiers [-fpermissive]
/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src/SoftwareSerial.h:94:8: note: in call to 'void SoftwareSerial::begin(long int)'
void begin(long speed);
/tmp/arduino_build_227628/sketch/Transciever.cpp: In member function 'TransReadStatus TranscieverHandler::checkForSignal()':
/tmp/arduino_build_227628/sketch/Transciever.cpp:36:29: warning: passing 'const SoftwareSerial' as 'this' argument discards qualifiers [-fpermissive]
/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src/SoftwareSerial.h:104:15: note: in call to 'virtual int SoftwareSerial::available()'
virtual int available();
/tmp/arduino_build_227628/sketch/Transciever.cpp:37:34: warning: passing 'const SoftwareSerial' as 'this' argument discards qualifiers [-fpermissive]
/home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial/src/SoftwareSerial.h:103:15: note: in call to 'virtual int SoftwareSerial::read()'
virtual int read();
In file included from /home/greg/GitRepos/WirelessSwitch/SwitchController/SwitchController.ino:32:0:
In file included from /tmp/arduino_build_227628/sketch/Transciever.cpp:5:0,
virtual int read();
Using library SoftwareSerial at version 1.0 in folder: /home/greg/other/arduino-1.8.9/hardware/arduino/avr/libraries/SoftwareSerial
exit status 1
