I have 2 sketches that control a fan using Arduino UNO, that I try to combine. The 1st is a timer, that turns a pin ON and OFF for a determined period of time. The pin signal drives a MOSFET that in turn switches a small fan ON and OFF. Since I need to control the speed of the motor, I would rather use the PWM control, however I am not sure how I can apply the timer since analogWrite command refers to a pin and value. Thanks
timer code:
const byte relayPin = 6; // relay module on pin 6
const byte monitorPin = 13; // builtin LED output
const unsigned long interval_1 = 1000UL * 15, interval_2 = 1000UL * 15; // ON timer + OFF timer in milliseconds
unsigned long currentMillis, previousMillis = 0;
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, HIGH); // relay OFF
pinMode(monitorPin, OUTPUT);
digitalWrite(monitorPin, LOW); // LED off
// put your main code here, to run repeatedly:
currentMillis = millis();
if (currentMillis - previousMillis >= interval_1)
digitalWrite(relayPin, LOW); // relay ON
digitalWrite(monitorPin, LOW); // LED on
if (currentMillis - previousMillis >= (interval_1 + interval_2))
digitalWrite(monitorPin, HIGH); // LED off
previousMillis = currentMillis; // reset
PWM code:
int PWMControl= 6;
int PWM_Input = A0;
int PWM_Value = 0 ;
pinMode(PWMControl, OUTPUT);
pinMode(PWM_Input, INPUT);
void loop()
PWM_Value = analogRead(PWM_Input);
PWM_Value = map(PWM_Value, 0, 1023, 0, 255);
analogWrite(PWMControl, PWM_Value);
