I want to communicate to an ARM microprocessor via I2C protocol (Multitech mDot, which uses Mbed platform). I successfully receive data from it (and got it displayed on Arduino's serial monitor), but when I want to send data from the Arduino I don't receive nothing on the other end. This is my sketch:
#include <DHT.h>
#include <Wire.h>
// Sensor temperatura, humedad DHT11 (test).
#define DHTPIN 10
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// Comunicacion i2c con nodo lora. 7bitaddress 010 1001 (r/w)
#define SLAVE_ADDRESS 0x29
// Variables globales de sensores
float h;
float t;
Wire.begin(SLAVE_ADDRESS);
Wire.onReceive(receiveEvent);
dht.begin();
Serial.begin(9600);
delay(5000);
h = dht.readHumidity();
t = dht.readTemperature();
// Comprobamos si ha habido algĂșn error en la lectura
if (isnan(h) || isnan(t)) {
Serial.println("Error obteniendo los datos del sensor DHT11");
return;
Serial.print("Humedad: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperatura: ");
Serial.print(t);
Serial.println(" *C ");
// Total de bytes del arreglo de datos a transmitir: 28 bytes.
void receiveEvent(int howMany) {
Serial.print("Mensaje recibido por i2c desde MDOT LoRa Node: ");
while (Wire.available() > 0) {
Serial.print(char(Wire.read()));
Serial.println();
char enviar = "Cacatua";
Wire.write(enviar);
return;
I wanted to know if this schematic is correct and if the wire write as it is written is performed. If so, I will need to see what is wrong with the code on my ARM device.
