I am trying to combine the two sensors (pulse sensor using this library and LM35 temp)(on a Arduino UNO board),but there is a problem with them when is a noise at the pulse sensor .The values are fluctuates especially the LM35 it goes from 31 degrees (normal value ) to 25-50 and even the pulse one changes .
Here are the results .
The code is this(I got the code form the Getting_BPM_to_Monitor sketch ) :
#define USE_ARDUINO_INTERRUPTS true // Set-up low-level interrupts for most acurate BPM math.
#include <PulseSensorPlayground.h> // Includes the PulseSensorPlayground Library.
const int sensor = A5; // Assigning analog pin A5 to variable ‘sensor’
float tempc; //variable to store temperature in degree Celsius
float vout; //temporary variable to hold sensor reading
// Variables
const int PulseWire = 0; // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED13 = 13; // The on-board Arduino LED, close to PIN 13.
int Threshold = 550; // Determine which Signal to "count as a beat" and which to ignore.
// Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
// Otherwise leave the default "550" value.
PulseSensorPlayground pulseSensor; // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
Serial.begin(9600); // For Serial Monitor
// Configure the PulseSensor object, by assigning our variables to it.
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED13); //auto-magically blink Arduino's LED with heartbeat.
pulseSensor.setThreshold(Threshold);
// Double-check the "pulseSensor" object was created and "began" seeing a signal.
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !"); //This prints one time at Arduino power-up, or on Arduino reset.
int temp = analogTemp();
Serial.print(temp);
Serial.println("Temp");
if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
// Serial.println("♥ A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
int myBPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an "int".
// "myBPM" hold this BPM value now.
Serial.print("BPM: "); // Print phrase "BPM: "
Serial.print(myBPM); // Print the value inside of myBPM.
Serial.println(" A HeartBeat Happened ! ");
delay(20); // considered best practice in a simple sketch.
float analogTemp() {
vout = analogRead(sensor);
vout = (vout * 500) / 1023;
return vout; // Storing value in Degree Celsius
