I needed a magnetometer with a high Output Data Rate (ODR). This is because I wanted to measure AC magnetic fields of around 20-80 Hz. So I decided to go with the MMC3416xPJ prototyping board which has an ODR of 800 Hz (https://au.mouser.com/new/memsic/memsic-mmc3416xpj-sensors/). I have never written an I2C interface for a sensor myself so I probably messed up. The datasheet for my sensor can be found here. I can get the product ID from the sensor correctly so that means the wiring is correct and some of the code is correct. But when I print out the measurements, they give me overflow values instead of the Earth's magnetic field. BTW I am developing this on Arduino board. Any help would be appreciated. My code can be seen below -
Magnetometer.h
#ifndef MAGNETOMETER_H
#define MAGNETOMETER_H
#include "General.h"
#include <Wire.h>
#define MAGNETOMETER_I2C_ADDRESS 0x30
#define X_OUT_LOW 0x00
#define X_OUT_HIGH 0x01
#define Y_OUT_LOW 0x02
#define Y_OUT_HIGH 0x03
#define Z_OUT_LOW 0x04
#define Z_OUT_HIGH 0x05
#define STATUS 0x06
#define INTERNAL_CONTROL_0 0x07
#define INTERNAL_CONTROL_1 0x08
#define RO 0x1b
#define R1 0x1c
#define R2 0x1d
#define R3 0x1e
#define R4 0x1f
#define PRODUCT_ID 0x20
class Magnetometer
  public:
    Magnetometer();
    void Setup();
    void Test();
  private:
    void TestConnnection();
    void ReadRawData();
#endif
Magnetometer.cpp
#include "Magnetometer.h"
Magnetometer::Magnetometer()
void Magnetometer::Setup()
    Wire.begin(SDA, SCL);
    TestConnnection();
    Wire.beginTransmission(MAGNETOMETER_I2C_ADDRESS);
    Wire.write(INTERNAL_CONTROL_1);
    Wire.write(0x00);
    Wire.endTransmission();
    Serial.println("Magnetometer Setup");
void Magnetometer::Test()
    ReadRawData();
    Serial.println("Magnetometer Test");
    delay(1000);
void Magnetometer::ReadRawData()
    int16_t RawMx, RawMy, RawMz;
    byte status = -1;
    // 1-3
    Wire.write(INTERNAL_CONTROL_0);
    Wire.write(0x01);
    // 4-7
    Wire.write(STATUS);
    Wire.requestFrom(MAGNETOMETER_I2C_ADDRESS, 1);
    status = Wire.read();
    Serial.print("status = "); Serial.println(status);
    while ((status%2) != 1)
        Serial.println("Data not ready");
    Serial.println("Data ready");
    // 8-17
    Wire.write(X_OUT_LOW);
    Wire.requestFrom(MAGNETOMETER_I2C_ADDRESS, 6);
    RawMx = Wire.read();
    RawMx |= Wire.read()<<8;
    RawMy = Wire.read();
    RawMy |= Wire.read()<<8;
    RawMz = Wire.read();
    RawMz |= Wire.read()<<8;
    Serial.print("RawMx: "); Serial.print(RawMx);
    Serial.print(" RawMy: "); Serial.print(RawMy);
    Serial.print(" RawMz: "); Serial.println(RawMz);
    float scaleFactor = 2048;
    float convertToMircoTelsa = 100;
    float Mx, My, Mz;
    Mx = (float) RawMx / scaleFactor * convertToMircoTelsa;
    My = (float) RawMy / scaleFactor * convertToMircoTelsa;
    Mz = (float) RawMz / scaleFactor * convertToMircoTelsa;
    Serial.print("Mx: "); Serial.print(Mx);
    Serial.print(" My: "); Serial.print(My);
    Serial.print(" Mz: "); Serial.println(Mz);
    // Serial.print("Wire.ava = "); Serial.println(Wire.available());
void Magnetometer::TestConnnection()
    byte id = -1;
    while (id != 6)
        Wire.write(PRODUCT_ID);
        id = Wire.read();
        if (id != -1)
            Serial.println("Cannot connect to Magnetometer");
    Serial.println("Magnetometer TestConnnection Success");
If you guys suggest me any other magnetometers that have a high ODR (at least above 300 Hz), it would be really appreciated.
VE7JRO
  • 2,515
  • 29
Perhaps a set/reset before configuring the device helps:
writeRegister(MMC34160PJ_CTRL0, 0x80);          // refill cap
delay(50);
writeRegister(MMC34160PJ_CTRL0, 0x20);          // set
//delay(10);
delay(50);
writeRegister(MMC34160PJ_CTRL0, 0x40);          // reset
//delay(10);
kellogs
  • 136
