I am trying to build a robot that detects cubes of a certain color, and later picks them up.
I was planning to use a camera and process the image, but I was told that Arduino is not capable of image processing.
Now, I was thinking that I could maybe use a photoresistor that is enclosed by a green light filter sheet (so that only the light of a certain color can pass). Thus, if my robot is facing a cube of the color I want, the photoresistor should detect this.
Is this at all possible? I know how filters work in theory, but I have never used one before.
If not, is there another way to try to detect color using an Arduino?
tony gil
  • 378
  • 26
Nick Heumann
  • 187
Use a TCS230 photo sensor and a 6500K light source to color correct your objects.
This hookup will get you started
This sketch, courtesy of Best-Microcontroller-Projects will get you going. Read the tutorial and dont forget to calibrate.
// Detect colors using TCS230.
// Arduino uno pins for control of TCS230
#define TCS320_OE 7
#define TCS320_S0 10
#define TCS320_S1 11
#define TCS320_S2 2
#define TCS320_S3 3
#define TCS320_OUT 4
#define variance 50  // Acceptable detection error 2%.
#define SEL_RED  \
   digitalWrite(TCS320_S2,LOW);digitalWrite(TCS320_S3,LOW)
#define SEL_GREEN \
   digitalWrite(TCS320_S2,HIGH);digitalWrite(TCS320_S3,HIGH)
#define SEL_BLUE \
   digitalWrite(TCS320_S2,LOW);digitalWrite(TCS320_S3,HIGH)
#define SEL_CLEAR \
   digitalWrite(TCS320_S2,HIGH);digitalWrite(TCS320_S3,LOW)
#define TWO_PER \
   digitalWrite(TCS320_S0,LOW);digitalWrite(TCS320_S1,HIGH);
#define debug(a) Serial.println((a));
#define NUMCOL 5
// int RGB[NUMCOL][3]; // Five colors with 3 elements.
// Array of NUMCOL strings len 10. 11 for null.
// char colname[NUMCOL][11];
// Typical values for 2% dividers (set variance to 50).
int RGB[NUMCOL][3]={
   {248,647,393},
   {188,261,265},
   {404,710,546},
   {506,493,304},
   {930,1199,837},
char colname[NUMCOL][11]={
"red",
"yellow",
"brown",
"blue",
"black",
   pinMode(TCS320_OE,OUTPUT);
   pinMode(TCS320_S0,OUTPUT);
   pinMode(TCS320_S1,OUTPUT);
   pinMode(TCS320_S2,OUTPUT);
   pinMode(TCS320_S3,OUTPUT);
   pinMode(TCS320_OUT,INPUT);
   TWO_PER;
   digitalWrite(TCS320_OE,LOW); // On always.
   Serial.begin(115200);
   Serial.println("TCS230 color detector");
unsigned long get_TCS230_reading(void) {
  unsigned long val;
  noInterrupts();
  val = pulseIn(TCS320_OUT,HIGH,20000); // 2000us=2ms  2Hz min.
  interrupts();
  return val;
static int clr,red,green,blue;
uint16_t detect(void) {
   unsigned long val;
    SEL_RED;
    red = val = get_TCS230_reading();
    Serial.print("RED: "); Serial.print(val);
    SEL_GREEN;
    green = val = get_TCS230_reading();
    Serial.print(" GREEN: "); Serial.print(val);
    SEL_BLUE;
    blue = val = get_TCS230_reading();
    Serial.print(" BLUE: "); Serial.print(val);
    Serial.print(" \n");
int withinEQ(int c, int xl, int xh) {
   if (c>=xl && c<=xh) return 1;
   return 0;
// Compare a value to a value and variance.
int compare(int c, int v, int err) {
int xh=v+err, xl=v-err;
   if (withinEQ(c,xl,xh)) return 1;
   return 0;
uint8_t chr,i,fnd;
   if (Serial.available()>0) {
      chr = Serial.read(); // Consume.
      // Find color match.
      detect();
      fnd=0;
      for (i=0;i<NUMCOL;i++) {
     if ( compare(red,RGB[i][0],variance) &&
          compare(green,RGB[i][1],variance) &&
          compare(blue,RGB[i][2],variance)
        ) { // Found
          Serial.print("Col is :");
          Serial.println(colname[i]);
          fnd=1;
          break;
      if (!fnd) Serial.println("NOT Found");
tony gil
  • 378
  • 26
Nice theory but since you're facing real-world conditions and not ideal ones, I think you'll have a hard time with this approach. I.e. your cube is likely not the same shade of green that your filter lets through. What about lighting - do you have a neutral white light source? I recommend you take a look at this Arduino RGB Sensing Tutorial using the TCS230 Colour Sensor for a headstart.
pfabri
  • 169
