I'm new to ArduinoJSON - so perhaps it is a newbie's question.... but I wish to pass a StaticJsonDocument into a function as a parameter ( later on it should be implemented in a library ).
exmaple below shows test_1 what I wish to obtain, but by duplicating StaticJsonDocument, which I don't want to do.
How can test_1 should be written (as I tried in test_2)?
#include <ArduinoJson.h>
StaticJsonDocument<200> doc;
void createJSON() {
        doc["sensor"] = "gps";
        doc["time"] = 1351824120;
        JsonArray data = doc.createNestedArray("data");
        data.add(48.756080);
        data.add(2.302038);
        // Generate the minified JSON and send it to the Serial port.
        serializeJson(doc, Serial);
        Serial.println("JSON is created:");
        // Generate the prettified JSON and send it to the Serial port.
        serializeJsonPretty(doc, Serial);
bool test_1(StaticJsonDocument<100> _doc){
        serializeJson(_doc, Serial);
        return true;
bool test2(const JsonObject& _doc){
        Serial.println("HI");
        Serial.begin(9600);
        createJSON();
        test_1(doc);
        // not used in this example
guyd
  • 1,049
  • 26
  • 61
The StaticJsonDocument is a template class. The template value in <> is here only the size of the internal buffer, but every size used generates a different class. (memory usage!)
To have the parameter of the function take an StaticJsonDocument version instance, it must be the same version or a common base class. In this case the base class is JsonDocument.
If you don't use the reference symbol & the parameter is copied. In this case StaticJsonDocument<200> _doc or JsonDocument _doc would create a copy and that copy would be modified in the function. The object used as parameter value would be unchanged - empty.
So use
void test2(const JsonDocument& _doc) {
Juraj
  • 18,264
  • 49
