I'm using an ESP32 WROOM board to capture some data in the field and send it over using arduino json. However, the complete process of sending and receiving confirmation takes up around 12 seconds and my ESP is frozen in that time. As a result, I lose the data in that time window. Is there a way to reduce the upload time of the ESP or maybe continue taking data while it is uploading?
Here is my data sending code for reference.
jsonBuffer.clear();
JsonObject &rootObject = jsonBuffer.createObject();
JsonObject &dataObject = rootObject.createNestedObject("data");
JsonArray &X1dataObject = dataObject.createNestedArray("X1");
JsonArray &Y1dataObject = dataObject.createNestedArray("Y1");
JsonArray &Z1dataObject = dataObject.createNestedArray("Z1");
if (wifiMulti.run() == WL_CONNECTED) {
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println(WiFi.localIP());
if (send_flag) {
  send_flag = false;
  int connection_iterator = 0;
  int connection_iterator2 = 0;
  for (int iterator = 0; iterator < SAMPLE_SIZE; iterator++) {
    X1dataObject.add(X1dataArray[iterator]);
    Y1dataObject.add(Y1dataArray[iterator]);
    Z1dataObject.add(Z1dataArray[iterator]);
  rootObject["coreid"] = String(low, HEX) + String(high, HEX);
  //rootObject["coreid_high"] = String(high, HEX);
  rootObject["sample_time"] = int(time_taken);
  rootObject["firmware_version"] = FIRMWARE_UPDATE_VERSION;
  rootObject.prettyPrintTo(Serial);
  Serial.print("connecting to ");
  Serial.println(host);
  while ((!client.connect(host, httpsPort)) && !setup_mode) {
    connection_iterator++;
    Serial.println("connection failed! Retrying..");
    digitalWrite(LED2, HIGH);
    delay(5000);
    digitalWrite(LED2, LOW);
    delay(5000);
    if (connection_iterator >= 10)
      ESP.restart();
  if (client.verify(fingerprint, host)) {
    Serial.println("certificate matches");
  } else {
    Serial.println("certificate doesn't match");
  digitalWrite(LED_BUILTIN, HIGH);
  Serial.print("requesting URL: ");
  Serial.println(url);
  client.println(String("POST ") + url + " HTTP/1.0");
  client.println(String("Host: ") + host);
  client.println("Cache-Control: no-cache");
  client.println("Content-Type: application/json");
  client.print("Content-Length: ");
  client.println(rootObject.measureLength());
  client.println();
  //rootObject.printTo(client);
  Serial.println("NUMBER OF INTERRUPTS:");
  Serial.println(interruptCounter);
  Serial.println("request sent");
  while ((client.connected()) && !setup_mode) {
    connection_iterator2++;
    String line = client.readStringUntil('\n');
    if (line == "\r") {
      Serial.println("headers received");
      break;
    Serial.println("Waiting for response");
    delay(1000);
    delay(1000);
    if (connection_iterator2 >= 20)
      break;
  if (line.startsWith("{")) {
    Serial.println("esp8266/Arduino CI successfull!");
  } else {
    Serial.println("esp8266/Arduino CI has failed");
  Serial.println("reply was:");
  Serial.println("==========");
  Serial.println(line);
  Serial.println("closing connection");
  digitalWrite(LED_BUILTIN, LOW);
  // readRegister(INT_SOURCE, 1, &dummy_read);
VE7JRO
  • 2,515
  • 29
