Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 12452 bytes (38%) of program storage space. Maximum is 32256 bytes.
Global variables use 970 bytes (47%) of dynamic memory, leaving 1078 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Michel Keijzers
  • 13,014
  • 41
  • 58
Try to upload your code without any device connected to Uno. Disconnect all IO pins. Upload the code via onboard USB port.
RoK
It means there is no proper communication between the IDE and your Arduino. The reason can be many things:
  • RX/TX UART port used
  • USB port broken
  • USB cable broken
  • Arduino broken
  • USB port drivers not properly installed
  • Problem inside IDE
To troubleshoot you could try:
  • Disconnect RX/TX jumpers
  • Try another USB port
  • Remove other USB devices
  • Try another USB cable
  • Try another Arduino
  • Try another PC/laptop
  • Reinstall IDE
  • Reinstall USB drivers
Michel Keijzers
  • 13,014
  • 41
  • 58
