I would like to change this clock to u8g2.
It works fine with the esp8266 and oled 128x64.
ESP8266 with Oled 128x64
I would start by including the u8g2 library with #include and all display. with u8g2. replace.
What else should I consider.?
Thanks Else
This is my Code
#include <ESP8266WiFi.h>
#include <WifiUDP.h>
#include <String.h>
#include <Wire.h>
#include <SSD1306.h>
#include <SSD1306Wire.h>
#include <NTPClient.h>
#include <Time.h>
#include <TimeLib.h>
#include <Timezone.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
// Define NTP properties
#define NTP_OFFSET   60 * 60      // In seconds
#define NTP_INTERVAL 60 * 1000    // In miliseconds
#define NTP_ADDRESS  "ca.pool.ntp.org"  // change this to whatever pool is closest (see ntp.org)
// Set up the NTP UDP client
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, NTP_ADDRESS, NTP_OFFSET, NTP_INTERVAL);
// Create a display object // SSD1306 display(0x3c, SDA, SCL);
SSD1306  display(0x3c, D2, D1); //0x3d for the Adafruit 1.3" OLED, 0x3C being the usual address of the OLED
//U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ 5, /* data=*/ 4, /* reset=*/ U8X8_PIN_NONE);
const char* ssid = "my ssid";   // insert your own ssid
const char* password = "my password";    // and password
String date;
String t;
const char * days[] = {"So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"} ;
const char * months[] = {"Jan", "Feb", "Mär", "Apr", "Mai", "Jun", "Jul", "Aug", "Sep", "Okt", "Nov", "Dez"} ;
void setup ()
  Serial.begin(115200); // most ESP-01's use 115200 but this could vary
  timeClient.begin();   // Start the NTP UDP client
  Wire.pins(4, 5);
  Wire.begin(4, 5);
  display.begin();
  display.flipScreenVertically();
  // Connect to wifi
  Serial.println("");
  Serial.print("Connecting to ");
  Serial.print(ssid);
  display.drawString(0, 10, "Connecting to Wifi...");
  display.display();
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi at ");
  Serial.print(WiFi.localIP());
  Serial.println("");
  display.drawString(0, 24, "Connected.");
  display.display();
  delay(1000);
void loop()
  if (WiFi.status() == WL_CONNECTED) //Check WiFi connection status
    date = "";  // clear the variables
    t = "";
    // update the NTP client and get the UNIX UTC timestamp
    timeClient.update();
    unsigned long epochTime =  timeClient.getEpochTime();
    // convert received time stamp to time_t object
    time_t local, utc;
    utc = epochTime;
  /*  // Then convert the UTC UNIX timestamp to local time
    TimeChangeRule usEDT = {"EDT", Second, Sun, Mar, 2, -0};  //UTC - 5 hours - change this as needed
    TimeChangeRule usEST = {"EST", First, Sun, Nov, 2, -60};   //UTC - 6 hours - change this as needed
    Timezone usEastern(usEDT, usEST); */
    TimeChangeRule CEST = {"CEST", Last, Sun, Mar, 2, 60};     //Central European Summer Time
    TimeChangeRule CET = {"CET ", Last, Sun, Oct, 3, 0};       //Central European Standard Time
    Timezone CE(CEST, CET);
    local = CE.toLocal(utc);
    // now format the Time variables into strings with proper names for month, day etc
    date += days[weekday(local)-1];
    date += ", ";
    date += day(local);
    date += " ";
    date += months[month(local)-1];
    date += " ";
    date += year(local);
    // format the time to 12-hour format with AM/PM and no seconds
    if(hour(local) < 10)  // add a zero if houre is under 10
      t += "0";
    t += hour(local);
    t += ":";
    if(minute(local) < 10)  // add a zero if minute is under 10
      t += "0";
    t += minute(local);
    t += ":";
    if(second(local) < 10)  // add a zero if minute is under 10
      t += "0";
    t+= second(local);
    // Display the date and time
    Serial.println("");
    Serial.print("Local date: ");
    Serial.print(date);
    Serial.println("");
    Serial.print("Local time: ");
    Serial.print(t);
    // print the date and time on the OLED
    display.clear();
    display.setTextAlignment(TEXT_ALIGN_CENTER);
    display.setFont(ArialMT_Plain_24);
    display.drawStringMaxWidth(64, 10, 128, t);
    display.setFont(ArialMT_Plain_10);
    display.drawStringMaxWidth(64, 48, 128, date);
    display.fillRect(1, 0, 126*timeClient.getSeconds()/59, 2);
    display.display();
  else // attempt to connect to wifi again if disconnected
    display.clear();
    display.display();
    display.display();
    delay(1000);
  delay(1000);    //Send a request to update every 10 sec (= 10,000 ms)
else
