I am trying to send commands via serial from Python to Arduino with the code below.
If I save this code in a dedicated python file "Stepper.py" (Python2.7 on Mac OSX) , the code runs successfully but nothing happens (the code does not trigger a motor connected to Arduino).
If I start terminal and run the same code from the interactive shell it works as expected.
How can I run it via a dedicated file ?
import serial
import time
ser = serial.Serial(port="/dev/cu.usbmodem144231", baudrate=9600, timeout = 0)
ser.write("200+")
time.sleep(1)
print ser.read()
digit
  • 193
Majenkos comment (above) solved the problem:
"You need to wait after opening the serial port for the board to finish resetting and the bootloader to run and exit before you can send any commands."
import serial
import time
time.sleep(1)
ser.write("200+")
print ser.read()
digit
  • 193
