I've actually done some tinkering with this sort of thing, or alternatively how to ensure previous EEPROM (or similar) settings are formatted on upload of a new sketch.
There are two values (C macros, in this case) that are baked into a program when it is compiled (for Arduino, the program is recompiled on each upload) that can be used to tell if the programming is "fresh."
The values you'd want are __DATE__ and __TIME__. They are converted to char arrays (strings, basically) at the time the compiler is run. You can store them directly to EEPROM, or use some sort of hash to convert it to a convenient number to store instead. Then, whenever the code boots, compare the stored value with the one computed from the values coded into the program. If they differ, overwrite the stored value with the new one and execute the run-once code.
Something along the lines of
byte i=0;
char checkVal[]=__TIME__ __DATE__;
for (int j=0; j<strlen(checkVal); j++){
i+=(byte)checkVal[j];//Creates a modulo 256 sum of the ASCII values of the chars (really poor hash)
if(EEPROM.read(26)!=i){//stored EEPROM location (arbitrary) -- feel free to use wear leveling, though, or some other method
//DO RUN-ONCE CODE HERE
EEPROM.write(26,i);//store the new value to stop it running again
