I am trying to have my sketch run a short series of tones (melody) through a Piezo buzzer after a selection is made by the user. I am getting a compilation error with my use of the tone function in the code I've written. I would kindly ask if someone in the "know" could have a look and provide me with a clear, step by step explanation of what I need to change to get it to work. I thank you in advance, your help is much needed and appreciated. -Steve
Here is my sketch:
#include <Stepper.h>
#include <Servo.h>
#include <Tone.h>
/*ARDUINO MOTOR SHIELD
 * The pin breakdown is as follows:
 * Function          Channel A   Channel B
 * Direction         Digital 12  Digital 13
 * Speed (PWM)       Digital 3   Digital 11
 * Brake             Digital 9   Digital 8
 * Current Sensing   Analog 0  Analog 1
const int stepsPerRevolution = 200;  // 1.8 deg. step angle(200 steps/360 deg. rev)
const int dirChA = 12;     // assigning name "dirChA" to pin 12
const int dirChB = 13;     // assigning name "dirChB" to pin 13
const int pwmChA = 3;      // assigning name "pwmChA" to pin 3
const int pwmChB = 11;     // assigning name "pwmChB" to pin 11
const int brkChA = 9;      // assigning name "brkChA" to pin 9
const int brkChB = 8;      // assigning name "brkChB" to pin 8
const int srvoMtr = 10;    // assigning name "srvoMtr" to pin 10
const int pButton1 = 4;    // assigning name "pButton1" to pin 4
const int pButton2 = 5;    // assigning name "pButton2" to pin 5
const int pButton3 = 6;    // assigning name "pButton3" to pin 6
const int pButton4 = 7;    // assigning name "pButton4" to pin 7
const int ledLight = 2;    // assigning name "ledLight" to pin 2
const int tonePin = 14;     // assigning name "tonePin" to pin 14
Stepper myStepper(stepsPerRevolution, dirChA, dirChB);  // initialize the stepper library on pins 12 & 13
Servo myServo;  // initialize the servo library to logical name myServo
int pButton1State = 0;     // variable for reading the pButton1 state as LOW or HIGH
int pButton2State = 0;     // variable for reading the pButton2 state as LOW or HIGH
int pButton3State = 0;     // variable for reading the pButton3 state as LOW or HIGH
int pButton4State = 0;   // variable for reading the pButton4 state as LOW or HIGH
int pButtonFlag = 0;     // variable for when button 1 has been pressed and released
int myServoPos = 0;    // variable for when servo has reached it's position
int myServoFlag = 0;   // variable for servo when any of the 4 pButton are pressed
 // 1 Stepper Motor
 pinMode(dirChA, OUTPUT);   // initialize pin 12 as an OUTPUT
 digitalWrite(dirChA, LOW);   //initialize pin 12 as LOW (pin voltage is 0 V)
 pinMode(dirChB, OUTPUT);   // initialize pin 13 as an OUTPUT
 digitalWrite(dirChB, LOW);   //intialize pin 13 as LOW (pin voltage is 0 V)
 pinMode(pwmChA, OUTPUT);   // initialize pin 3 as an OUTPUT
 digitalWrite(pwmChA, LOW);   //intialize pin 3 as LOW (pin voltage is 0 V)
 pinMode(pwmChB, OUTPUT);   // initialize pin 11 as an OUTPUT
 digitalWrite(pwmChB, LOW);   //intialize pin 11 as LOW (pin voltage is 0 V)
 pinMode(brkChA, OUTPUT);   // initialize pin 9 as an OUTPUT
 digitalWrite(brkChA, LOW);   //intialize pin 9 as LOW (pin voltage is 0 V)
 pinMode(brkChB, OUTPUT);   // initialize pin 8 as an OUTPUT
 digitalWrite(brkChB, LOW);   //intialize pin 8 as LOW (pin voltage is 0 V)
 myStepper.setSpeed(60);   // set the speed of the stepper motor to 60 RPM
 // 4 Push Buttons
 pinMode(pButton1, INPUT);   // initialize pin 4 as an INPUT
 digitalWrite(pButton1, LOW);   // initialize pin 4 as LOW (pin voltage less than 1.5V)
 pinMode(pButton2, INPUT);   // initialize pin 5 as an INPUT
 digitalWrite(pButton2, LOW);   // initialize pin 5 as LOW (pin voltage less than 1.5V)
 pinMode(pButton3, INPUT);   // initialize pin 6 as an INPUT
 digitalWrite(pButton3, LOW);   // initialize pin 6 as LOW (pin voltage less than 1.5V)
 pinMode(pButton4, INPUT);   // initialize pin 7 as an INPUT
 digitalWrite(pButton4, LOW);   // initialize pin 7 as LOW (pin voltage less than 1.5V)
 // 1 Led Light
 pinMode(ledLight, OUTPUT);   // initialize pin 2 as an OUTPUT
 digitalWrite(ledLight, LOW);   // initialize pin 2 as LOW (pin voltage is 0 V)
// 1 Piezo Speaker
 tone();
 pinMode(tonePin, OUTPUT);   // initialize pin 1 as an OUTPUT
 digitalWrite(tonePin, LOW);   // initialize pin 1 as LOW (pin voltage is 0 V)
  //Read button state (pressed or not pressed?)
  pButton1State = digitalRead(pButton1);   // read the state of pButton1 as LOW or HIGH
  pButton2State = digitalRead(pButton2);   // read the state of pButton2 as LOW or HIGH
  pButton3State = digitalRead(pButton3);   // read the state of pButton3 as LOW or HIGH
  pButton4State = digitalRead(pButton4);   // read the state of pButton4 as LOW or HIGH
  // check if the pushbutton is pressed. If it is, the pbuttonState is HIGH:
  if (pButton1State == HIGH) {
     pButtonFlag=1;  // change pButton1Flag variable
     if (pButtonFlag == 1){
        digitalWrite(pwmChA, HIGH);   // enable power to stepper
        digitalWrite(pwmChB, HIGH);   // enable power to stepper
        myStepper.step(40);          // step forward 40 steps to position 1
        digitalWrite(pwmChA, LOW);    // disable power to stepper
        digitalWrite(pwmChB, LOW);    //disable power to stepper
        myServoFlag=1;             // change ServoFlag variable to dispense chocolate
        if (myServoFlag == 1){
           myServo.attach(srvoMtr);   // attaches the servo library to pin 10
           for (myServoPos = 0; myServoPos <= 100; myServoPos += 1) { // goes from 0 degrees to 100 degrees in steps of 1 degree
               myServo.write(myServoPos);    // tell servo to go to position in variable 'myServoPos'
               delay(15);                    // waits 15 milliseconds for the servo to reach the position
           myServo.detach();   // detaches the servo library from pin 10
           delay(2000); // hold position OPEN for 2 sec
           for (myServoPos = 100; myServoPos >= 0; myServoPos -= 1) { // goes from 100 degrees to 0 degrees in steps of 1 degree
               myServo.write(myServoPos);    // tell servo to go to position in variable 'pos
               delay(15);
        myServoFlag=0;         // changes myServoFlag value back to zero (0)
        digitalWrite(ledLight, HIGH);   // turn on light to indicate chocolate is dispensed
        if (ledLight == HIGH){
           digitalWrite(tonePin, HIGH); // turn on Piezo speaker
           // Play Melody
           void tone();{
           tone(tonePin, 233, 203.992851562);
           delay(226.658723958);
           delay(4.82252604167);
           tone(tonePin, 184, 412.325976562);
           delay(458.139973958);
           tone(tonePin, 184, 99.8262890625);
           delay(110.918098958);
           tone(tonePin, 155, 99.8262890625);
           tone(tonePin, 184, 203.992851562);
           delay(236.303776042);
           tone(tonePin, 233, 555.555);
        digitalWrite(tonePin, LOW);    // turns off Piezo speaker
        myStepper.step(-40);          // step backward 40 steps to position 0
        digitalWrite(pwmChB, LOW);    // disable power to stepper
        digitalWrite(ledLight, LOW);   // turns off light to indicate the sequence is completed
        pButtonFlag=0;                // changes pButtonFlat value back to zero (0)
        delay(2000);
  // position 2
  if (pButton2State == HIGH) {
     pButtonFlag=1;  // change pButtonFlag variable
        myStepper.step(80);          // step forward 80 steps to position 2
        delay(2000);
           for (myServoPos = 0; myServoPos <= 100; myServoPos += 1) { // goes from 0 degrees to 100 degrees in steps of 5 degrees
           delay(2000);
               delay(15);
           // Play Melody
        myStepper.step(-80);          // step backward 80 steps to position 0
        pButtonFlag=0;   // changes pButton2Flag value back to zero (0)
        delay(2000);
    // position 3
    if (pButton3State == HIGH) {
          myStepper.step(120);          // step forward 120 steps to position 3
          delay(2000);
                 delay(15);                    // waits 3 sec for the servo to reach the position
             delay(2000);
               delay(15);
             // Play Melody
          myStepper.step(-120);         // step backward 120 steps to position 0
          pButtonFlag=0;   // changes pButton3Flag value back to zero (0)
          delay(2000);
    // position 4
    if (pButton4State == HIGH) {
          myStepper.step(160);          // step forward 160 steps to position 3
          delay(2000);
          Serial.println("\nServo Flag = 1 - Dispense Chocolate");
             delay(2000);
               delay(15);
             // Play Melody
          myStepper.step(-160);         // step backward 160 steps to position 0
          delay(2000);
Maximilian Gerhardt
  • 3,646
Stevie_D
First off
Even if compiled your code will not work; in the tone function reference you can read:
Use of the tone() function will interfere with PWM output on pins 3 and 11 (on boards other than the Mega).
You seem to want to use both pins 3 & 11 for PWM output; you cannot also use the Tone library while using these pins. Although you never actually called analogWrite(...) on these pins so it probably won't do what you want anyway.
Second
the line:
void tone();{
is absolutely wrong; one cannot declare a function within another function in C++ or C. And this isn't even a valid definition either. This is probably your compilation error, your compiler should tell you what line number this is on!
Third
It seems you don't quite understand what the code you are attempting to use even does. I would assume that you haven't read, or understood, the documentation.
The tone library doesn't work like this; at best this does nothing, at worst it disrupts the tone library
  delay(15);
myServo.detach();
This is not how you use the servo library! .attach() is generally used in setup, .detach() is almost never used.
This is not how you use the stepper library! Steppers are generally powered 100% of the time. When un-powered they cannot generate torque or hold a position! Also those pins aren't associated in any way with the stepper, you assigned dirChA and dirChB to the stepper. The stepper library assumes it is talking to a stepper driver, not driving the stepper itself.
Finally
Your code repeats itself too much, and is too verbose, and does many nonsensical things or things that result in nothing or something very different that the comments imply was intended.
You need to structure you code better, refactor into re-useable functions and remove code that doesn't do anything
esoterik
  • 628
