I'm using the GxEPD2 library to communicate with an E-Paper display. I now wanted to use the drawPaged method of this library with an object display.
I also have written my own class from which I want to print stuff on the display.
Here's the relevant code for the MyClass.h:
class MyClass{
//some variables and methods
void drawClass(); //this is public
void drawClassCallback(const void* v1); //this is private
// this is actually a uint8_t --^
And here's the MyClass.cpp:
void MyClass::drawClass(){
//some display preparation
uint8_t var; //A variable to pass information from the callback to this method since it is needed later
display.drawPaged(std::bind(&MyClass::drawClassCallback, this, &var));
//some code where I need var with info from the callback
I'm getting the following error:
no matching function for call to 'GxEPD2_BW::drawPaged(std::_Bind_helper::type)'
note: candidate: void GxEPD2_BW::drawPaged(void ()(const void), const void*) [with GxEPD2_Type = GxEPD2_290; short unsigned int page_height = 296u] void drawPaged(void (drawCallback)(const void), const void* pv)
I've also tried display.drawPaged(std::bind(&MyClass::drawClassCallback, this, std::placeholders::_1), &var) without success.
I've stumbled upon this post already, however the solution presented there (and the one used above) does not work in this case.
Why is that?
