I'm building a rig with multiple DSLR cameras. I need to synchronize the cameras to take a photos with lowest possible latency. The only constraint is we want the ability to address each camera individually if needed.
I've seen in other posts: Choosing wireless tech for lowest possible lag
NRF24L01+ seems to be a good choice. An answer on that post states: sending a 32 byte payload...283µs on 2Mbps mode.
Given the esp8266 has a clock speed of 80MHz/160MHz I'm not too concerned about the lag involved in processing the signals.
Most multi-cast information out there is for sensor arrays, so multiple out single in. I'm after resources on single out multiple in for NRF24L01+ networks.
Added bonus of esp8266 is that non timing critical tasks such as logging and error checking could be performed over wifi so NRF24L01+ would be purely for one -way triggering.
If each camera had it's own esp8266 based board with attached NRF24L01+ hardware and was given an address in software from 0-255, is it possible to broadcast a single 32 byte packet of data where each bit would represent a camera address and have all receiver devices receive the same signal, do an AND against it's address and trigger if needed?
Geordie
  • 195
Yes, that should work, however also think about the following issues:
  • What if one (or more) camera does not receive the signal? You might need to add an ACK signal, but of course this will reduce the latency (a lot). If you don't want an ACK signal
  • To prevent an ACK, you can send the signal many times (and cameras who already processed the signal not react for a fixed amount of time). Of course it will received by the other cameras (at least) 283 us later.
  • If reliability is important, you could try using a less high speed, the latency will go up, but reality too.
Also you probably can fire the cameras even faster, if you first send the address bytes (4 bytes). And than send the shoot signal which can be in principle 1 bit. You can use one of the bits for that in case 128 cameras would suffice. Or send one byte extra which contains the signal to shoot.
Michel Keijzers
  • 13,014
  • 41
  • 58
