I'm trying to take a sketch and turn it into a class for a library I'm making, but I'm getting compile issues.
This is not a duplicate as suggested. as i explain in the comment and my answer. Thank you all for your help - as I am new to creating libraries - figured I would attempt something correctly for a change :)
Here is the original sketch: Gotten here
#include <ros.h>
#include <sensor_msgs/BatteryState.h>
#define K 0.00472199
#define CELLS 6
#define MAX_CELLS 12
double cell_const[MAX_CELLS] =
1.0000,
2.1915,
2.6970,
4.1111,
4.7333,
6.6000,
6.6000,
7.8293,
8.4667,
9.2353,
11.0000,
11.0000
ros::NodeHandle nh;
sensor_msgs::BatteryState batt_state;
ros::Publisher batteryState("battery_state", &batt_state);
void setup()
// Initialize the ROS node.
nh.initNode();
nh.advertise(batteryState);
// Populate battery parameters.
batt_state.design_capacity = 2200; // mAh
batt_state.power_supply_status = 2; // discharging
batt_state.power_supply_health = 0; // unknown
batt_state.power_supply_technology = 3; // LiPo
batt_state.present = 1; // battery present
batt_state.location = "Crawler"; // unit location
batt_state.serial_number = "ABC_0001"; // unit serial number
batt_state.cell_voltage = new float[CELLS];
void loop()
// Battery status.
double battVoltage = 0.0;
double prevVoltage = 0.0;
// Populate battery state message.
for (int i = 0; i < CELLS; i++)
// Read raw voltage from analog pin.
double cellVoltage = analogRead(i) * K;
// Scale reading to full voltage.
cellVoltage *= cell_const[i];
double tmp = cellVoltage;
// Isolate current cell voltage.
cellVoltage -= prevVoltage;
battVoltage += cellVoltage;
prevVoltage = tmp;
// Set current cell voltage to message.
batt_state.cell_voltage[i] = (float)cellVoltage;
// Check if battery is attached.
if (batt_state.cell_voltage[i] >= 2.0)
else
batt_state.present = 0;
// Update battery health.
batt_state.voltage = (float)battVoltage;
if (batt_state.voltage > CELLS * 4.2)
batt_state.power_supply_health = 4; // overvoltage
else if (batt_state.voltage < CELLS * 3.0)
batt_state.power_supply_health = 3; // dead
else
batt_state.power_supply_health = 1; // good
// Publish data to ROSSERIAL.
batteryState.publish( &batt_state );
nh.spinOnce();
delay(1000);
Here is my header file:
#ifndef battery_h
#define battery_h
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <ros.h>
#define CELLS 6
#define CRITICAL 0.30
1.0000, 2.1915, 2.6970, 4.1111,
4.7333, 6.6000, 6.6000, 7.8293,
8.4667, 9.2353, 11.0000, 11.0000
ros::NodeHandle nh;
ros::Publisher batteryState("/battery/info", &batt_state);
class Battery
private:
void updateBatteryHealth();
double battVoltage;
double prevVoltage;
public:
void begin();
void updateBatteryState();
#endif
This is my cpp file:
#include "battery.h"
void Battery::begin(){
// Launch ROS node and set parameters.
nh.initNode();
// Setup publishers/subscribers.
batt_state.cell_voltage = new float[CELLS]; // individual cell health
void Battery::updateBatteryState() {
battVoltage = 0.0;
prevVoltage = 0.0;
// Reset Power Supply Health.
prevVoltage = tmp;
if (batt_state.cell_voltage[i] <= 3.2)
batt_state.power_supply_health = 5; // Unspecified failure.
else{
void Battery::updateBatteryHealth() {
if (batt_state.present)
float volt = batt_state.voltage;
float low = 3.0 * CELLS;
float high = 4.2 * CELLS;
batt_state.percentage = constrain((volt - low) / (high - low), 0.0, 1.0);
else
batt_state.voltage = 0.0;
batt_state.percentage = 0.0;
// Update power supply health if not failed.
if (batt_state.power_supply_health == 0 && batt_state.present)
else
nh.spinOnce();
this is the error im getting simply by calling the Battery::begin function in my main class:
libraries/KBROSRobot/KBROSRobot.cpp.o (symbol from plugin): In function `KBROSRobot::KBROSRobot()':
(.text+0x0): multiple definition of `nh'
sketch/rob_test.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `batt_state'
(.text+0x0): multiple definition of `batteryState'
(.text+0x0): multiple definition of `cell_const'
/var/folders/m4/lq13_j5j23qc0l2wp8dqmt4h0000gp/T//cczNyzqC.ltrans1.ltrans.o: In function `begin':
/Users/keith.brown/Documents/Arduino/libraries/KBROSRobot/KBROSRobot.cpp:9: undefined reference to `Battery::begin()'
collect2: error: ld returned 1 exit status
exit status 1
