I found this question: Set PWM frequency to 25 kHz
It is useful, however, I want to use it to generate ~14KHz?
int d = 0; // pwm value
void setup()
// Sets Timer1 to Phase Correct
// F_CLOCK / ( Prescaler * ORCR1A * 2 ) = Freq in Hz
// 16000000 / (1 * 512 * 2 ) = 15625 Hz
TCCR1A = _BV (WGM10) | _BV (WGM11) | _BV (COM1B1); // Phase Correct
TCCR1B = _BV (WGM13) | _BV (CS10); // Phase Correct / Prescale 1
OCR1A = 571; // Sets Top to 512 --571
OCR1B = 0; // Sets Pwm =
pinMode(10, OUTPUT);
pinMode(0, INPUT)
void loop()
d = (analogRead(0));
d = map(d, 0, 1023, 0, 512);
OCR1B = d;
I used this sketch to test the frequency which works good. If I change the pinMode(10, OUTPUT);, into: pinMode(9, OUTPUT); and there is no output, why?
