I'm trying to upload a Blink example to run on a pro-micro (leonardo) but it is not working anymore (it was just working yesterday).
Steps to reproduce:
- Plug the device in USB port
- Open Blink example in Arduino IDE (version 1.8.8)
- Select the port and board accordingly to Arduino Leonardo
- Compile and try to upload it.
The code compile successfully but when uploading it just halts. The ide console displays:
avrdude: error: programmer did not respond to command: exit bootloader
Forcing reset using 1200bps open/close on port /dev/ttyACM0 PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {} Uploading using selected port: /dev/ttyACM0 /home/fabio/Downloads/pacotes/arduino-1.8.8/hardware/tools/avr/bin/avrdude -C/home/fabio/Downloads/pacotes/arduino-1.8.8/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/ttyACM0 -b57600 -D -Uflash:w:/tmp/arduino_build_350609/Blink.ino.hex:i
avrdude: Version 6.3-20171130 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/fabio/Downloads/pacotes/arduino-1.8.8/hardware/tools/avr/etc/avrdude.conf" User configuration file is "/home/fabio/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : /dev/ttyACM0 Using Programmer : avr109 Overriding Baud Rate : 57600 AVR Part : ATmega32U4 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00 flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00 lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 Programmer Type : butterfly Description : Atmel AppNote AVR109 Boot LoaderConnecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
A strange behavior I noticed is each time I plug the device again in the usb port different leds are light up, some times only RX, sometimes only TX and sometimes none (the power led is always on)
What could be happening here? Can it be the problem on the hardware?
