One of the requirements of my projects is to send data from my application to the Arduino robot.
I have windows 10, and my robot is Arduino Uno. The Bluetooth I'm using on my robot is HC-06.
The app side:
- I'm writing some script (With the format I've created)
- Then converting it into JsonString
- Opening the port and sending a start communication signal.
- Sending the JsonString, each represents another command and they're separated with a special character that can't be written in the script. Here's the problem, I tried sending string length of 256 bytes (not a JsonString) just to test the Bluetooth.
The test I did in my robot
- I read the data
- Turned the led on
- Waited (data.length() / 10) seconds
- Turned the led off
For my data of 256 bytes, the led was ON for 12.8 seconds, which is 128 bytes. And sometimes when I changed some stuff The time was 6.4 seconds.
C# (Application)
string data = @"0101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101";
protocolBT.BTcontroller.OpenPort();
protocolBT.BTcontroller.SendChar(ProtocolBT.COM_OpenChar);
protocolBT.BTcontroller.SendBigData(data);
protocolBT.BTcontroller.ClosePort();
The Bluetooth Class
public class BluetoothController
private readonly SerialPort _serialPort;
public BluetoothController(string portName, BaudRate baudRate)
_serialPort = new SerialPort(portName, (int)baudRate, Parity.None, 8, StopBits.One);
public static bool IsBluetoothSupported()
return BluetoothRadio.IsSupported;
public static void SetConnection()
if (IsBluetoothSupported())
if (BluetoothRadio.PrimaryRadio.Mode == RadioMode.PowerOff)
BluetoothRadio.PrimaryRadio.Mode = RadioMode.Connectable;
public void OpenPort()
try
_serialPort.Open();
catch(IOException IOex)
throw IOex;
public void ClosePort()
_serialPort.Close();
public void SendData(string msg)
try
if (_serialPort.IsOpen)
byte[] data = Encoding.UTF8.GetBytes(msg);
_serialPort.Write(data, 0, data.Length);
catch (Exception ex)
throw ex;
public void SendBigData(string msg)
try
foreach (char ch in msg)
SendChar(ch);
throw ex;
public void SendChar(char ch)
try
byte[] data = Encoding.UTF8.GetBytes(new char[]{ ch });
throw ex;
And this is my Arduino test code
#include <SoftwareSerial.h>
#define RX 10
#define TX 11
SoftwareSerial BT = SoftwareSerial(RX, TX);
String startCom = "ยป";
String MessageStart = "";
bool isListen = false;
String data = "";
int yellow = 12;
void setup()
// Define LED
pinMode(yellow, OUTPUT);
// Test yellow led
digitalWrite(yellow, HIGH);
delay(1000);
digitalWrite(yellow, LOW);
// Define Bluetooth
pinMode(RX, INPUT);
pinMode(TX, OUTPUT);
BT.begin(9600);
void loop()
if(isListen == false)
readStartCommand();
else if(isListen == true)
readAllData();
int len = data.length();
if(len > 0)
robotLedOn(0); // Turn on the yellow led
for(int i = 0; i < len; i++) // Wait (len * 0.1) second
delay(100);
robotLedOff(0); // Turn off the yelloe led
void readStartCommand()
if(BT.available() > 0)
char ch = BT.read();
Message += ch;
if(MessageStart == startCom)
// Blink the yellow led if the start communication command recieved
robotLedOn(0);
delay(1000);
robotLedOff(0);
delay(2000);
MessageStart = "";
isListen = true;
void readAllData()
while(BT.available() > 0)
data += BT.read();
isListen = false;
I tried to put the 256 bytes data manually to string in the Arduino and the timer was on 25.6 seconds. So I think that there is a limit for the size of the data that Bluetooth can handle.
Note:
- I need Json because I have complicated commands, not only leds. Some of the commands require multi-parameters from different types.
- Soon I will get Arduino-Mega because I don't have enough pins in my Uno.
Tried:
Change the timeout, it still stops receiving at 128 bytes. with read() and setTimeout(100-2000) Timer result: 12.8 seconds With readString() and setTimeout(100-2000) Timer result: 6.4 seconds
My WriteBufferSize in the PC Bluetooth is 2048 bytes. So I'm pretty sure that all the data is sent.
Different Baud Rates and using the Library instead of the The only change is that now the timer stops at 15.5 seconds...
Use BT.flush() and all my data is sent 100% for sure, the problem is in receiving in my Arduino. I think there is a buffer limit for the data...
Using another Bluetooth device, still the result is 15.5 seconds instead of 25.6 seconds.
